1st wreck :)
6 replies to this topic
  • AliveInMyOde
Posted June 27, 2003 - 06:07 PM
Hey guys
i was riding durin the evening when i hit a freakin hole and did an endo. it as crazy but i am fine and suprisingly the bike is fine. the handle bars had rotated forward a little in the clamps and the forks were slightly tweaked but fixed all that already. only thing pisses me off is i broke the mount from the front number plate to the forks. anyone else break this yet? how much does a new front number plate cost? see ya'll
-Billy
  • endurodog
Posted June 27, 2003 - 06:20 PM
No idea how much on that but glad to hear you survived!
  • huskyrider
Posted June 28, 2003 - 03:38 AM
If all that happened to your bars was that they rotated a little bit, your very lucky.
My stock bars were pure JUNK. They were bent after my first wreck, which really wasn't even a bad getoff.
  • Rich_in_Orlando
Posted June 28, 2003 - 04:31 AM
If you're talking about the headlight shroud, that's about 70 bucks. I've busted mine up so many times. I just use thin sheet aluminum and rivets to hold mine together. It's not pretty, but if I got a new one every time I crashed I'd have a garage full of busted up headlight shrouds.
  • the426master
Posted June 28, 2003 - 09:55 AM
I did the same thing and I cut the old tabs off and got some aluminum cut two peices about 3inches buy3/4 inch and bent them at a 90 degree angle at the front drilled holes in them and bolted them two the old holes but you half two drill new holes in the front of your number plate :)
  • AliveInMyOde
Posted June 29, 2003 - 03:52 AM
Hey you don't have any pics of your number plate or some pics of someone who did it do ya? just like to see what it looks like. good idea
  • pymn2001
Posted June 29, 2003 - 08:12 AM
Wrecked the same and thought would like new but just got a strip of ally about one inch by 1/8 bent and shaped to match lugs with a vice took two minutes and stuck some heavy duty velcro and she's done matey it works a treat and saved myself a few quid and if you think its rubbuish you can get new this way it only pulls off with a hefty :tug :)
