Leaking fork seals
18 replies to this topic
  • downin
Posted September 22, 2010 - 03:07 PM
I have an 09 yz450f and it has about 20-25 hours on it. I have noticed lately that the fork seals have been seeping. I do what the shop manual says and clean them after each ride but they still seep while im riding. Is it normal for them to seep at all or am i looking at new seals?
  • arnego2
Posted September 22, 2010 - 03:30 PM
Hello there
How do you clean them? I use a finger of a small and slim plastic film about the thickness of a photo film. If that does not help you will need new seals. It is not really hard to change when having the tools. Her is video how to do in > video
Regards
Arnego2
  • downin
Posted September 22, 2010 - 03:32 PM
I use a goggle tear off and fits up in perfect. I kinda figured that once they start leaking its time for new ones thanks.
  • crf450319
Posted September 22, 2010 - 03:43 PM
Edited by crf450319, September 23, 2010 - 08:22 AM.
Posted September 22, 2010 - 05:15 PM
Rather than film, etc., I use a business card from which I have torn the bottom third off lengthwise. This leaves a torn, "fuzzy" edge that removes dirt better than just film.
  • STROKEDIESEL
Posted September 22, 2010 - 06:34 PM
very easy job!!! i had never touched suspension myself up until a couple works ago. i also bought the tools mentioned above and they dont take but like an hour to do both sides and both chambers your first time.
highly recommend buying the complete rebuild kit as well instead of just the seal and wiper all that and some oil and you will still be cheaper than the local shop and you'll have the tools for the innevitable.
  • Subby
Posted September 25, 2010 - 09:22 AM
SD,
Where do you buy the rebuild kit?
Thanks,
Subby
  • downin
Posted September 25, 2010 - 11:16 AM
I finally got all the dirt and mud out of the seals and they dont leak a bit.
  • STROKEDIESEL
Posted September 25, 2010 - 11:13 PM
glad to hear you got it. i wasnt so lucky on my attempt. you can pick them up from denniskirk though for future reference.
  • crush6742
Posted September 26, 2010 - 03:44 PM
I was just getting ready to start a similar thread. I have an '08 yz450f and just noticed that my forks were leaking oil today. Should I try to clean up around the seals first, or should I just take it into the shop to be fixed? If I take it in the shop, what is should I expect to pay to have this fixed?
  • downin
Posted September 26, 2010 - 04:18 PM
I would try cleaning them before id have them rebuilt.
  • crush6742
Posted September 26, 2010 - 04:29 PM
What did you use to clean yours with? I'll give that a try first.
  • downin
Posted September 26, 2010 - 05:23 PM
I used a google tearoff and slid it up in each fork and went the whole way around them in a sweeping manner. I had to repeat a couple times to get all the mud and dirt.
  • BBrown626
Posted September 26, 2010 - 06:37 PM
Don't pay a penny! Spend a few bucks getting the fork tube wrench and a seal driver from rockymountain and buy a set of seals from them too. Watch a video or two and dig into those forks. They are really easy to replace. The first time you replace the seals the savings will more than pay for the tools. :ride::thumbsup::banghead:
  • STROKEDIESEL
Posted September 26, 2010 - 06:52 PM
for me it was easy. i went to the shop and got a quote as i didnt have the proper fork tools. quote was 140-190 depending on if the bushings needed to be changed or not.
so i did it myself
motion pro seal driver/bullet -48
tusk wrench and cap thingy - 20
oil-15
msr seals -24
$107
bring on the next leak i am ready!!!!!
watch the video on rocky mountain as already stated , read the manual and get er done.
Posted September 26, 2010 - 08:15 PM
Start by reading the whole thread. The question was asked and answered earlier.
  • crush6742
Posted September 27, 2010 - 07:00 AM
I read the thread. Downin said he was using the tear off to clean his seals. But that didn't seem to work. I was under the impression he had given up on this method. You mentioned using the buniness card as a better solution after that. I wasn't sure if he switched to the business card method with better results. I don't have any tear off.
  • downin
Posted September 27, 2010 - 01:28 PM
I didnt need to use a buisness card, just a tear off but like i said i had to repeat a couple times to get all the mud and dirt out.
  • STROKEDIESEL
Posted September 27, 2010 - 02:04 PM
i cleaned mine with 35mm negatives. worked for an hour or so and started leaking again.
  • 0 replies
  • Hot  36 replies
  • Hot  28 replies
