05 yz 450 woods gearing (sprocket) recommendation
4 replies to this topic
  • crmaverick
Posted September 20, 2010 - 03:39 PM
Im looking to gear down my 05 yz 450 for the woods to help compensate for only having a 4 speed. would going down a tooth in the front do the job, or should I go up a tooth in the rear sprocket in addition to this?
thanks
Posted September 20, 2010 - 04:44 PM
Gearing down won't compensate for a 4 speed, exactly. The low gears of the 4 and 5 speed YZ450 transmissions are the same. 4th gear is in between where 4th and 5th in a 5 speed would be, so the 4 speed lacks a little top speed on the 5, but that's it.
But you may want to drop down a bit because of the rather tall, MX first gear, as some do. In that case, either approach is OK, although using a smaller front is more likely top allow you to change gearing without changing the chain length, and the '05 had a fairly large rear cog already.
  • crmaverick
Posted September 22, 2010 - 11:41 AM
so would going down to a 13t in the front make a noticeable difference, and is the stock front sprocket a 14t on an 05?
thanks
  • tech24
Posted September 22, 2010 - 12:34 PM
Yes, give it a try plus its cheaper than a larger rear and like gray said chain will fit you'll just loose a little adjustment range.
Posted September 22, 2010 - 12:57 PM
thanks
Yes to both. Since the chain ratio is 3-something to one, one tooth at the front is like three at the rear.
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  28 replies
