re-gearing recommendations
1 reply to this topic
  • crmaverick
Posted September 20, 2010 - 03:03 PM
Im looking to gear down my 05 yz 450 for the woods to help compensate for only having a 4 speed. would going down a tooth in the front do the job, or should I go up a tooth in the rear sprocket as well this?
thanks
  • mach1jonny
Posted September 20, 2010 - 10:45 PM
Depends what are you running currently. 1 tooth on the front is ruffely 3 teeth in the back. Meaning = reduce 1 tooth in the front is like going up 3 teeth in the rear. Calculation is- number of teeth on the rear sprocket divided by the number of teeth on the front sproket the will give you the secondary drive ratio. On my WR I felt it had a lack of torque, I went up 1 tooth on the rear sprocket - I'm happy.
Less teeth on front or more teeth on rear = more torque * Would not go lower then 13T on front
More teeth on front or less teeth on rear = more top end
Hope this makes sense
Good luck
Edited by mach1jonny, September 20, 2010 - 10:50 PM.
Clarification
