Special tools
15 replies to this topic
  • Guest_Guest_*
Posted February 17, 2001 - 02:25 PM
What kind of special tools will I need to work on my 426 besides the usual metric sockets, wrenches, and torque wrench? What has anyone found to make certain jobs easier?
Thanks,
KC
  • vznx1w
Posted February 17, 2001 - 06:16 PM
You don't need any special tools to work on the 426, unless you want to take the valves out of the head (requires a valve spring compresser). You will need a set of feeler gauges to check valve adjustment, but you probably already have a set of those-if not you can them anywhere. Everything else is pretty much like a 2-smoke--tools wise.
  • PK
Posted February 18, 2001 - 07:24 AM
If you don't have the spark plug wrench, that is the one part that is unique that I can think of other than the above mentioned parts.
PK
  • Boit
Posted February 18, 2001 - 10:04 PM
My favorite tools are my "T" handles. They make removing/installing the side panels and radiator shrouds much easier and faster. You just need to remember that it's easy to strip things with all the torque you can apply with these things. I also got a little wheel-type screw driver that fits perfect in the carb pilot fuel screw from Pro-Tec. I'd be lost without this little screwdriver. This is a very short screwdriver with a little knurled wheel mounted on the stem for gripping with your fingers. Also, the blade is made so that it fits perfectly in the cavity and you can easily feel when it slips into the screw groove.
  • motoman393
Posted February 19, 2001 - 06:18 PM
Boit...I am jealous it takes me 10 mins to adjust my stupid fuel screw! How much was that screwdriver and do they have a website?
Garrett
I get my kicks on a 2001' YZ426!
Friendswood, TX
  • Boit
Posted February 19, 2001 - 09:27 PM
Yes: www.pro-tecperformance.com
Take a look at their offerings. I'm also using their top triple clamp. The fit is top-notch. Is it a "must have"? Not really. But the fuel screw screwdriver is a "must have". I was getting tired of burning my knuckles and getting finger cramps. I think this little tool runs about $15 and is worth twice that.
  • dirtdad
Posted February 20, 2001 - 03:46 AM
motion pro also makes a tool for the FCR carb that even has a few extra attachements and a little case to store it in. White Brothers and Chaparral carry it for around
$12.00!
  • jj
Posted February 20, 2001 - 07:47 AM
The Pro-Tec tool is a life saver! Now if I could only find the damn thing...
JJ from WA - 99 WR; WR timed, EKN Needle, Scotts stabalizer, Scotts triple clamps, Pro-Tapers, Michelin S-12's, Terry Cable hot start, MSR Raptor clutch lever, Moose skid plate, Works frame guards, Acerbis Pro Rally guards, Renthal MD-soft grips, Factory Effex graphics, YZ IMS seat base, YZ Factory Effex seat foam and gripper seat cover, YZ rear fender
  • flyinguitars
Posted February 20, 2001 - 11:54 AM
What do you guys use to change you rear shock spring preload? Its got those 2 big ringnuts. Do you use a spanner or just tap them with a punch? Thanks
Mike
  • Hick
Posted February 20, 2001 - 03:35 PM
A punch to set the sag, but I’ve got a Motion Pro “universal” spring wrench for changing springs.
Okay, okay, I use a big, long screwdriver and a big hammer. So sue me.
  • flyinguitars
Posted February 20, 2001 - 05:14 PM
[QUOTE]Originally posted by Hick:
[B]
LOL.....Thanks Hick,
I used a brass punch with a mallet to set my sag. It didnt really bung up the ring nuts like I thought it would, but I felt like a real dumbass while I was banging away...I even closed the garage doors so the neighbors wouldnt see me taking a hammer to my new 6000.00 bike. I couldnt find a spanner or ring nut wrench at any of the local tool depts. (sears, home depot, pep boys) I guess I'll have to check with snap on or better yet harbor frieght.
Thanks Hick,
Mike
  • flyinguitars
Posted February 20, 2001 - 05:27 PM
Hey Hick,
Check it out, no more hammering....I plan on losing about 25lbs by the summer, so I'll be adjusting my sag with these: http://www.harborfre...temnumber=41243
Mike
  • Hick
Posted March 02, 2001 - 11:14 AM
Hey, those look like they’d work great, and the whole set is less than I paid for my cheesy little Motion Pro wrench. I love Harbor Freight. Let us know how they work, they look like an improvement over anything I’ve seen.
  • enmerdeur
Posted March 03, 2001 - 01:53 PM
I made a small fuel screw adjuster by getting a small flat bladed power screwdriver bit and pressing on a brass nut. It doesn't have the self aligning feature but cost less than $2!
  • enmerdeur
Posted March 03, 2001 - 06:10 PM
Also for the spark plug I bought a 5/8 sparkplug socket with a built in swivel at Sears that works great for getting the plug out. I combine it with an extension and it makes it very easy to change the plug. What is everyone else using for their plug? Has anyone managed to devise a system to remove the plug without removing the tank?
  • dirtlord
Posted March 05, 2001 - 10:12 PM
I just use a 10" vacumm line which fits nicely over the spark plug. I had lost that little rubber piece which fits inside the spark plug socket many moons ago, but I had to take out the tank every time....
  • Hot  50 replies
  • 5 replies
  • 0 replies
  • 10 replies
  • Hot  38 replies
