Dr. D Carbon Fiber Exhaust Repair
6 replies to this topic
  • gabrams
Posted September 08, 2010 - 04:02 AM
Has anyone attempted to repair a carbon fiber exhaust? I have the Dr. D carbon fiber muffler on a 2009 YZ450 I recently bought and apparently the previous owner did not repack it soon enough and it developed a soft spot on the number plate side of the muffler. It is not worn through or cracked so i was debating either putting some epoxy on a stainless steel plate and bridging the soft area to the stronger area and then riveting it in place or buying a carbon fiber repair kit and laying a couple layers of carbon fiber onto the weak area. Does anyone have any thoughts on this or what would be the best way? I called DrD and they would not just sell me a replacement carbon fiber can (or SS which I would prefer). They would however let me send it back for repairs but I figured I could still take a shot at it because either way the can is toast. Also, what approximately does my muffler exhaust temp get to?
Edited by gabrams, September 08, 2010 - 06:24 AM.
Posted September 08, 2010 - 08:13 AM
... what approximately does my muffler exhaust temp get to?
That depends a great deal on the condition of the packing, which is why that's so important to a CF can. (BTW, the cans on both my SS DRD systems are aluminum) A well packed muffler can still reach temps of over 300 ℉. It can go much higher with a hole in the packing. The mid pipe at the muffler can run around 500 or higher fairly easily.
  • KJ790
Posted September 08, 2010 - 09:01 AM
The carbon fiber used for the cans uses a high temp resin. Typical resin like that found in a cf repair kit won't hold up to the temperature. You could try using a little JB weld on a thin piece of tin on the inside of the can like you initially mentioned. As long as you keep good packing in it that might be fine.
On a side note, I bought a carbon fiber silencer that already had a soft spot in it just like you describe. I got it cheap and figured I would just run it. I repacked it often and the spot never got any worse and never cracked. After 2 years I am still using it.
Posted September 08, 2010 - 09:48 AM
Just my mind wandering around on its own, but a double layer of Maier heat tile (bottom of the page) between the packing and the can on the inside might also be effective.
  • gabrams
Posted September 08, 2010 - 09:55 AM
Thank you very much.
  • lostonmonday
Posted September 10, 2010 - 11:08 AM
Here's a pretty good resin that'd work to fix the soft spot. link
My favorite resin is Resin Services' HTR-212 resin with HT-386-99 hardener. It can handle up to 350-400f, is clystal clear, semi-flexible and super tough. The only down side is the price: $100/gallon, and they don't sell it by the quart. If you plan on reskinning your muffler with another layer of cf, it might make sense to buy a whole gallon, then make a few carbon parts to match the muffler!
Edited by lostonmonday, September 10, 2010 - 12:03 PM.
  • yz007f
Posted September 12, 2010 - 08:38 AM
I had the same problem with a c/f muffler on my 09. I tipped it over in a corner and my boot was under the number plate and it kinda made the cf soft in one part. I just ordered a alum one from Dr.d. But I do wanted to fix this one and use it as a spare. I was just gonna use JB weld on the inside, which I'm sure would work just fine! But haven't gotten around to doing it yet..
  • Hot  36 replies
  • Hot  50 replies
  • Hot  30 replies
  • Hot  28 replies
