Water Pump Life
4 replies to this topic
  • wondermuscle
Posted September 07, 2010 - 06:57 AM
My water pump failed after only 40hrs on my 2008, specifically the water seal. I'm replacing the shaft, both seals and the bearing. I have messed around with cleaning up shafts and re-using them. I'd rather spend the $30 on a new shaft and not have to worry about it.
Just out of curiosity, how long have your water pumps lasted?
  • tribalbc
Posted September 07, 2010 - 07:20 AM
Mine went at around 200hrs. First I just did the seals and felt like a dummy when seeing what my shaft looked like, but I didn't have the parts, so I threw it together to see how it went. It didn't leak for 100hrs untill last winters rebuild when I replaced seals, bearing and shaft. I now have over 150hrs on my replacement and all is good. Will see how it looks when I rebuild the motor this winter.
  • redhurricane
Posted September 07, 2010 - 08:18 AM
4 years and still no leaks on my 2006.
Question to those that are having failures-
Are you running spec coolant? Water wetter, engine ice, etc may not have the same lubrication properties as the recommended coolant.
  • wondermuscle
Posted September 07, 2010 - 09:54 AM
I run the pink Maxima stuff. I have boiled over my bike a few times recently and I think it just got too hot and damaged the seals.
Anyother thoughts?
  • tribalbc
Posted September 07, 2010 - 10:47 AM
Anyother thoughts?
I also use the pink Maxima stuff, well the Kool aide additive added to regular antifreeze/water.
I boil my bike over regularly :ride:
But when I replaced mine the shaft was very obviously worn so I don't think it's boiling and seals????
