New 07 450 knocking...?
14 replies to this topic
  • climaxx dirtbikes
Posted September 02, 2010 - 10:04 AM
I changed the oil for the third time with non-syn recently and put a new aluminum skid plate on. I expected a little more engine noise but not this loud knock. Is this normal because of the skid plate. Oil level is perfect and still really fresh only 4 hrs on it.
  • WR450FGreg
Posted September 02, 2010 - 11:28 AM
They do tend to sound noisier when you fit an aluminium skid plate.
Greg
  • SXP
Posted September 03, 2010 - 11:41 AM
I'll go out on a limb here and gurantee that what you are hearing is your chain slapping on the swingarm slider. Make sure your chain is properly adjusted.
  • climaxx dirtbikes
Posted September 04, 2010 - 02:44 AM
Nah, this knock is when at idle or at any rpm for that matter with the bike not moving
  • bulldog1331
Posted September 04, 2010 - 07:16 AM
My '09 WR450 sounds like a rock crusher at idle compared to other bikes...but runs like a dream. Seems all 4 stroke Yammies are like that. I've had Yamahas for 30+ years and they all sound like that.
  • climaxx dirtbikes
Posted September 04, 2010 - 11:01 AM
Good to know. Thanks!
  • stev0
Posted September 07, 2010 - 02:48 AM
clutch basket? What the hours on your bike? Mine got a nasty knock around 500 :bonk:
  • climaxx dirtbikes
Posted September 08, 2010 - 05:48 AM
Im not exactly sure since I havent put an hour meter on yet but not many prob 15hrs
  • stev0
Posted September 08, 2010 - 05:55 AM
drain the oil and check for shavings, just to be sure :ride:
  • climaxx dirtbikes
Posted September 09, 2010 - 02:50 AM
Will do thanks.
  • masterraptor
Posted September 10, 2010 - 02:30 AM
Mine sounds like a rock crusher too. The sticky says this is normal unless there is a big hole in the case to let rocks in.
  • mtna_buzz
Posted September 10, 2010 - 04:55 AM
I have a new 2008 (about 12 hrs) with an aluminum skid plate - with the same noise. Kind of a heavy knocking which is worse when the clutch is engaged (lever out). Took the plate off for the oil change - rode around the yard and it was much quieter.
Figure it's the normal noise- and I'll have to get used to it (or get some ear plugs!)
  • sacfelix
Posted September 10, 2010 - 05:57 AM
If you dont hear those noises than you should be worried when you own a Yamaha.LOL!
  • climaxx dirtbikes
Posted September 13, 2010 - 10:31 AM
Thanks
  • chevytrkn1
Posted September 26, 2010 - 05:58 AM
Mines been noisey ever since new as soon as i put the aluminum skid plate on
