All new 2011 YZ450F!
22 replies to this topic
  • andy250
Posted September 01, 2010 - 08:30 AM
... The only update is the clutch pushrod :bonk:
http://www.yamaha-mo...0/features.aspx
New for 2011:
* New clutch lever and pushrod for more consistent clutch feel during long motos.
  • cowboyona426
Posted September 01, 2010 - 08:58 AM
Thats not true. They also made it ugly with the white lower shroud.
  • MOTOPHILE
Posted September 01, 2010 - 09:05 AM
New for 2011:
Might be in market for 2011 soon. 2011 yz450 is in the running...
  • honda907
Posted September 01, 2010 - 04:05 PM
Hopefully it will keep the clutch from fading. I thought the 2010 just had more power and therfore the clutch heated up more than my 09. I love the feel of the 09 over the 10 (clutch feel)
  • Troutman
Posted September 01, 2010 - 04:50 PM
Well I guess I am glad I did not wait for the 2011. The 10 (and now the 11) are incredible bikes! They don't need any changes except a pipe and a little work with the tuner to suit your style and your ready to rip :bonk:
  • brentn
Posted September 01, 2010 - 05:07 PM
It has a 200ml larger tank as well.
There are always small changes, but they never friggen mention them.
They have a white 2011 and two blue 2010's at my dealership right now... Been checking them out every few days after work as it's on my way home. Every single time I've gone there not one sales guy has approached me, and i"m literally sitting on the bike, slow kicking it, checking out how it differs from my yz250 for a good 10 minutes...
When I decide to buy and get my $ I'm going to buy it somewhere else.
  • honda907
Posted September 02, 2010 - 03:54 AM
If you need a pipe for THAT bike, you are way faster than us mortals!!
  • Jeepentj
Posted September 02, 2010 - 03:56 AM
If the fuel tank is 200ml larger (less than 7 ounces) I wonder if the fuel pump changed and is slightly smaller? I can't imagine Yamaha setting out to increase the gas tank and having it be a mere 7 ounces larger.
  • patrickincc
Posted September 02, 2010 - 11:44 AM
no reason to change a good thing.
  • andy250
Posted September 02, 2010 - 12:35 PM
Agreed - my only real complaint about the 2010, is how fast the clutch seems to fade. I think I'll be picking the new part up once it's available...
  • honda907
Posted September 02, 2010 - 04:23 PM
I second that part.
  • brentn
Posted September 02, 2010 - 05:09 PM
I didn't check the weight differences.. Does 200ml of gas weigh 7 ounces?
  • andy250
Posted September 02, 2010 - 07:50 PM
I think he meant fluid ounces... 200ml = 6.76oz
200ml of gasoline weighs about 0.34 lbs, or 0.15 Kg
  • Troutman
Posted September 03, 2010 - 04:06 PM
Not so much faster but bigger, 6' - 5" and 230lbs every bit counts. The pipe (Full Yosh) also helped the revs ALOT! It revs to the moon now :bonk: The stocker seems to plug it up.
  • steve_97060
Posted September 03, 2010 - 05:24 PM
exactly, my DRD pretty much eliminated the issue with the heavy hit and allows it to rev out more. much broader power band now...
  • rcmxracing
Posted March 07, 2011 - 08:12 AM
Can someone explain how the different 2011 clutch actuation arm makes a difference in clutch fade? Also, does it affect the clutch pull feel? Easier, harder? I have the 2010 and have to agree after about 3 laps I am spinning my quick adjust faster than a rodent wheel - mega play.
  • honda907
Posted March 07, 2011 - 11:57 AM
I see on the GYTR store, the complete clutch for a 2011( fibers, springs and metal plates) has a different part number than the 2010. Other than that, I can't find any different part numbers.
  • rcmxracing
Posted March 07, 2011 - 12:06 PM
2011 part listed 19th under clutch components:
33D-16381-10-00 PUSH LEVER COMP
The part number IS different than the 2010 part number.
  • brentn
Posted March 07, 2011 - 05:10 PM
What about the fuel pump? I don't have access to 2011 parts, just 2010. Here is the part # for 2010
FUEL PUMP COMP.
2747746
(8107740-001)
Also, not to sure why they changed the clutch as the only issue I had was that once the clutch was warmed up, there was a bit more play in the slack of the cable, causing me to re-adjust. I found the sweet spot, and it seems if you have like half a mm of play when cold, by the time it warms up there is still enough tension to completely dis-engage the clutch.
Posted March 08, 2011 - 07:50 AM
I don't know where you came up with that number, but it's not a Yamaha PN.
The pump is 33D-13907-00-00 for both years.
http://www.yamaha-mo...parts/home.aspx
  • Hot  38 replies
  • Hot  113 replies
  • 0 replies
  • Hot  36 replies
  • 10 replies
