2010 450 Hot starting problems
5 replies to this topic
  • MXR176
Posted August 26, 2010 - 12:23 PM
Ok Im having a problem after the bike is hot with it wanting to start back up. When its cold it starts on the 2nd or 3rd kick. I have the less hit map in it. I ride 3 classes and theres time I only have a couple motos in between my next class and theres times it takes 10-20 kicks before its wanting to start. My 09 would start on the 3rd kick usually after it was hot and I didn't have to pull the hot start even. Anyone else having issues with this? If so what have you tried or found out? What works and what don't....
  • delmas
Posted August 26, 2010 - 03:02 PM
are you using the choke nob
  • MXR176
Posted August 26, 2010 - 04:55 PM
Nope!!!!!
  • Phil Hannah
Posted August 26, 2010 - 05:46 PM
When the bike is warm try holding the throttle at 1/8 to 1/4 open when kicking. I can start my bike in gear by doing this!
  • Joel-48
Posted August 26, 2010 - 07:26 PM
I have found that once the bike you have to start it old school like the 2-strokes. Give the throttle a twist when you kick it over. If it doesn't start right up I usually do one slow kick to get right a tdc and than a big one.
  • tech24
Posted August 27, 2010 - 06:15 AM
2 things work:
1. put in nuetral pull out the cold start/fast idle knob and it should fire 1 to 2 kicks
2. Hold throttle slightly open while kicking, nuetral works better but will start in gear
  • Hot  47 replies
  • 5 replies
  • Hot  28 replies
  • 0 replies
