yz 426f water pump
5 replies to this topic
  • akiyz426f
Posted August 25, 2010 - 10:14 AM
hello i was wondering if any one could shine some light one this matter for me. my water pump makes the winding nosie from my water pump i was wondering if that is normal.
Posted August 25, 2010 - 10:18 AM
How do you know it's the water pump?
  • akiyz426f
Posted August 25, 2010 - 10:27 AM
because if u get down and lissen to it u can notice its it , i was wondering if its just the inpeller making that noise ???
Posted August 25, 2010 - 10:35 AM
There are a number of things in that immediate area that can and sometimes normally do make such noises. There are 9 straight cut gears under the right crankcase cover that might produce a whining noises without there being a problem. If it actually is the water pump, you might want to investigate it. Could be a bearing.
  • akiyz426f
Posted August 25, 2010 - 10:57 AM
thank you
how offten shoould it be checked ?????
  • Ryan426
Posted August 25, 2010 - 02:37 PM
i
thank you
When you think there is a problem would be a good time to check it.:bonk:
