Wr250f starter in wr450f??
4 replies to this topic
  • a56kuser
Posted August 24, 2010 - 06:38 PM
I got a 04 450f and I bought it with the e start broken ....the only starter I see on eBay is for a 06 250f .... Just wondering if it'll work ...
On a side note is there a diagnostic I can do to see if its just my starter motor that is broken??? I heard sometimes it's just the brushes that need to be replaced
Thanks in advance
  • YamaLink
Posted August 25, 2010 - 05:23 AM
I don't want to say "yeah of course it'll fit and work."
There are many possible broken parts, and I'm not quite sure what part you purchased. I'd go to http://www.yamaha-mo...parts/home.aspx and see if they are at least the same part number.
  • a56kuser
Posted August 26, 2010 - 01:34 PM
Well i didn't purchase it yet but they are definitely different part numbers so I better lay off that purchase for now ....
Now to figure out if I need a new starter motor or not ......
  • ysr50speed
Posted August 27, 2010 - 06:34 AM
hey backoff my ebay250 starter...I saw it first :foul: . I wanted to do the same thing and put it in my 450 but couldn't figure out if it would work. So I just bought a new one from the tt store. If you don't want to spend the kind of money on a new one, you can send your motor to Ricks Electric and they will rebuild it for 160ish. There is also a place online that sells refurbed ones for 180 with your core in return.
If you have a manual and volt meter, you can follow the steps in the manual. I would think if you were getting 12 volts to your starter motor when you held down the estart button and if your starter wasn't turning then I would say its your starter motor....but yet again I'm not expert here. good luck :bonk:
  • a56kuser
Posted August 27, 2010 - 01:36 PM
The 250 motor is all yours buddy :bonk:
I guess I'll try diagnose the problem first ....
I don't even know what sound it makes if any cause my bike doesn't have a battery or starter button..... But I have them on order
