426 shock linkage problem
9 replies to this topic
  • jecole360
Posted August 20, 2010 - 07:34 PM
I was riding my 02 yz426 today an it seemed fine until I took a break. When I got off the bike I noticed the rear suspension didn't rise back up. When I go to lift it or push down on it there is an aweful squeaking noise coming from the linkage area. So to replace the linkage bearings do I need to remove the rear wheel or can I get it off without removing anything?
  • StoneRacer
Posted August 20, 2010 - 07:43 PM
I would take it completely apart and grease all the bearings.:bonk:
  • jecole360
Posted August 21, 2010 - 07:59 AM
Can I do that without removing the real wheel or swing arm?
  • StoneRacer
Posted August 21, 2010 - 04:38 PM
I think Ur going to see that its a lot easier if you take it completely apart. you can check the wheel bearings, swing arm bearings, and the linkage.
  • Ryan426
Posted August 21, 2010 - 07:32 PM
Yep, no short cuts when comes to the rear linkage.
  • jecole360
Posted August 21, 2010 - 08:23 PM
Well I got it all apart. I had to remove the subframe to get the shock out but it was no problem. I got the linkage off and to it apart to inspect the bearings and they were bone dry. I just ordered a kit from all balls and should be getting it in a few days. Hopefully that will fix the problem. Do any of you guys know what the torque specs are for the linkage or where I can find info on torque specs for a yz426?
  • nathanpa01
Posted August 21, 2010 - 08:40 PM
The owners manual. Lots of useful information in that bound pack of paper
  • jecole360
Posted August 25, 2010 - 04:49 PM
I dont have an owners manual yet.
Posted August 25, 2010 - 05:37 PM
Why not?
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
  • nathanpa01
Posted August 26, 2010 - 09:09 AM
I was just about to tell you the manual is available for download, but I see greyracer is already one it. Download the manual, or buy a hard copy, it is very useful
  • Hot  50 replies
  • Hot  113 replies
  • Hot  36 replies
  • On January 15, 2017
  • 10 replies
