Confirmation on torque spec for front sprocket: 08 450
8 replies to this topic
  • silentZ
Posted August 20, 2010 - 08:18 AM
Manual says 54ft lbs. I did this and then bent the lock washer around the nut. I checked it after one ride and it was totally loose. I removed the lock washer and torqued again with a new lock washer. Am I reading this correctly?
  • usp4u
Posted August 20, 2010 - 08:21 AM
make sure your torque wrench is not using in/lbs.
  • silentZ
Posted August 20, 2010 - 08:55 AM
My wrench only has Ft lbs and NM
  • mikedabike
Posted August 20, 2010 - 12:24 PM
How is it coming loose if the washer is installed properly?:bonk:
  • silentZ
Posted August 21, 2010 - 04:50 PM
I bent the washer back out, then checked it and was able to spin the nut with my fingers.
  • mikedabike
Posted August 21, 2010 - 07:15 PM
Probably wasn't seated good to begin with. Did you have any mud or other crap behind the washer? I usually stand on the rear brake to keep it from moving. It is hard to tighten these by yourself sometimes.
  • Pukeballs
Posted August 23, 2010 - 03:04 PM
Just a shot in the dark here, but you may need your torque wrench re-calibrated. What brand torque wrench are you using?
  • BBrown626
Posted August 23, 2010 - 07:05 PM
No torque wrench is needed. Just snug it up good and bend the washer over.
  • Wiz636
Posted August 24, 2010 - 07:19 AM
This is what I was thinking. I don't see any other way it could come loose with the washer tab bent over it.
