header freeze...
12 replies to this topic
  • jayh300
Posted August 19, 2010 - 04:30 PM
have read about freezing your header to get dents out...
never thought it would work....
before
after 1 freeze
dent is 90% gone... probably wont even mess with it anymore...
thanks guys
jay
  • xr650r2000
Posted August 19, 2010 - 04:35 PM
cool ill do that to mine
  • bentsprocket
Posted August 20, 2010 - 06:06 AM
Looks good... I know I just got the phone with you. But, does these weaken the material? I.E. since no heat was used to make it malleable. Meaning if hit again does it increase chances of break through?
  • jayh300
Posted August 20, 2010 - 06:08 AM
i am sure we will test that.... soon...
  • TLRam1
Posted August 20, 2010 - 12:30 PM
How much water did you put in the pipe? Fill it up, just the bottom where the bend is, just enough to cover the damaged area?
  • jayh300
Posted August 20, 2010 - 12:37 PM
I had no idea... so i stood it up in the freezer and filled the water to just over the bend of the pipe.. i did not cap it at all.. i had heard of some splitting so i started off kinda conservative.. one day in the freezer..
  • 123BigcoopDawg576
Posted August 20, 2010 - 12:45 PM
Yup, dont cap it and only free past the dent...this way it wont split :bonk:
  • jayh300
Posted August 20, 2010 - 01:02 PM
it worked good.. i was kinda shocked.. i know it is not that bad of a dent, but i wanted to try to get it out.. got plenty o time right now with the lh ankle in an ortho boot. may freeze it one more time to see if it takes the small dents out.. looks much better..
  • MaxPower
Posted September 04, 2010 - 07:34 PM
[COLOR="Green"]use your own judgement however I have taken a pretty well dented Ti 450 pipe and over filled it and froze it many times with no problem at all[/COLOR]
  • climaxx dirtbikes
Posted September 05, 2010 - 03:20 PM
can that work for a 2 stroke pipe?
  • bentsprocket
Posted September 05, 2010 - 04:13 PM
Yes it can. A pipe is a pipe.
  • MaxPower
Posted September 05, 2010 - 05:25 PM
[COLOR="Green"]I would be a little more careful with a 2 stroke pipe as they have welded seems that I feel are more of a weak point than a solid pipe[/COLOR]
  • climaxx dirtbikes
Posted September 06, 2010 - 04:45 AM
Good point. Thanks
