YZ450F silencer
3 replies to this topic
  • ray
Posted August 18, 2010 - 02:55 AM
I thought some of you that are always asking about the 08/09 silencers might like to see these pics. I took mine off and never started the bike with it and have carried it as a spare. I decided to modify it and remove the two baffles. I might try to bolt it on just to see how it works. As large as the diameter of the core is (a KTM 450F core I had on the shelf fit perfectly inside it) and as short as the system's length, it's probably pretty loud. I mainly just did this to have something to mess with. After it was put back together, it looked the exact same as it did before, just 6 ounces lighter, louder and with a straight through silencer. But if I need it as a spare, it should be able to be bolted up with the same jetting as my FMF Ti system.
http://i565.photobuc...7/YZ450F006.jpg
http://i565.photobuc...7/YZ450F005.jpg
http://i565.photobuc...7/YZ450F008.jpg
http://i565.photobuc...7/YZ450F007.jpg
Drill the welds and remove the inner cone. I used a small piece of another core and taked it on to cover these holes and to make sure the the strength.
http://i565.photobuc...7/YZ450F009.jpg
Cut the cone off the end cap. The core slides all the way up, so no fit problems.
http://i565.photobuc...7/YZ450F010.jpg
  • davcon
Posted August 18, 2010 - 03:32 AM
Thanks for the pics. I installed the PMB Endo on the stock can and you lose the cone by default.
http://www.thumperta...7517&highlight=
I didnt notice any difference in performance.
  • ray
Posted August 18, 2010 - 08:22 PM
I'm surprised you didn't notice some improvement. The two cones have to be fairly restrictive. The silcone/glue holds both sides on pretty good, so I used a propane torch to heat up the ends a little which seemed to help them come apart after drilling out the rivets. I have a X/C race this weekend, and I may throw it on Sat during practice to compare between it and my FMF. It took about an hour, and is basically a free mod, so if it works well, it might be worth considering for those still running the stock can.
  • davcon
Posted August 19, 2010 - 05:50 AM
2 cones? sorry, missed that note. I just removed the outer one. I have repacking material sitting on the bench waiting to be installed. Think I'll remove that inside cone and see what happens.
  • 0 replies
  • Hot  113 replies
  • 10 replies
  • Hot  36 replies
