Bleeding and bleeding and still no rear brakes.
3 replies to this topic
  • stev0
Posted August 16, 2010 - 05:03 AM
So I popped on my new braided hose and all was well. Untill I noticed on a ride Ive lost my rear brakes again. So I bled them (luckily I had an 8 wrench on me) and they worked(sort of) As soon as I switched off the bike, they vanished again.
So I decided to rebleed the system again. Hell Ive even reverse bled it, still nothing. I even removed the piston and cleaned it up, but it just does not want to move.
Any ideas? :banana:
  • William1
Posted August 16, 2010 - 05:34 AM
If you bled them and they worked and then later, they went soft again either you have a fluid leak, a stick caliper or a bad seal in the master cylinder.
  • stev0
Posted August 16, 2010 - 05:36 AM
I'm thinking it could well be a seal. Ive taken out the caliper. I think ill do the master cylinder now.
  • redhurricane
Posted August 16, 2010 - 10:21 AM
I had my master go bad, and was sucking air into the line. Cheap kit to replace the piston/seal, and been great ever since.
