IMS tank/radiator shroud problem
4 replies to this topic
  • Strattos
Posted August 15, 2010 - 10:55 PM
I've got a 3.1g IMS tank and YZ shrouds on my 08WR450. I've had it on for a while, but one thing that bothers me about the fitting is that I had to flex the radiators back a bit to get the bottom bolt to line up with the lower radiator shroud hole. Had to flex them back about a quarter of an inch. There's still some flex left if they had to move back any further - such as in a crash, but it still worries me.
Has anyone else had this problem?
Will this risk radiator life? Am I better off getting a file/knife and making the shroud hole bigger?
  • WR_Dave
Posted August 16, 2010 - 04:47 AM
I just used a couple of longer bolts and put a spacer between the radiator bolt clip and the shrouds. You may have to slightly bend the hole mount area back a bit for alignment purposes, I wouldn't be flexing the rads too much if I didn't have too. Just make sure you have a washer on both sides of the plastic around the bottom bolt hole on the shroud. :banana: WR Dave
  • kawi380
Posted August 16, 2010 - 05:14 AM
Mine were like that too for a little while, after a few hard crashes everything seems to fit just fine...
  • WB450
Posted August 16, 2010 - 09:22 AM
+1:thumbsup:
  • Strattos
Posted August 16, 2010 - 12:27 PM
Thanks guys. Might have another crack at mounting them. Cheers.
