header pipe repair
6 replies to this topic
  • strtdsmallproject
Posted August 13, 2010 - 06:55 PM
a couple of weeks ago i dented my fmf bomb header pipe. last weekend i crushed it real good. in the process i broke my arm and have plenty of time to fix the pipe. has anyone used http://www.piperepair.com/
  • bg10459
Posted August 16, 2010 - 01:19 PM
Just fill it with water and freeze it (the pipe, not your arm :banana:). Might take a few tries, but it should work.
  • sacfelix
Posted August 16, 2010 - 01:38 PM
If you do freeze it keep an eye on it or else it will split the side open. I found out the hard way.LOL!
  • jayh300
Posted August 17, 2010 - 06:15 AM
gonna try that on mine also.. put a little dent in it, then next weekend i broke my ankle, so i also have some extra time also... mine is about the size of a quarter so we will see...
  • Vegemite_luva
Posted August 17, 2010 - 10:14 AM
Freezing works but yes you will need to try several times so be patient.
  • WR450FGreg
Posted February 01, 2011 - 10:35 AM
If anyone is ever after an OEM header they are on fleaBay often and usually go very cheaply.
  • strtdsmallproject
Posted February 01, 2011 - 06:48 PM
I saw the post up again and needed to add that the on line pipe repair place did a great job. Im now runnin a moose fiber guard and havent had a single dent or problem this hare scramble season. I did cook the resin from the guard warming the bike before a race. I would have to recomend the guard though, just not shiney anymore.
