Baja reg/rec help
4 replies to this topic
  • darky82
Posted August 12, 2010 - 10:11 PM
Hey does any one know if the bajadesign dc reg/rec regulates both the ac and the dc side...:banana:
  • William1
Posted August 13, 2010 - 08:23 AM
The BD rect/reg takes all the power input, rectifies it to DC and regulates it. It does not output both AC and DC.
  • Kawidad
Posted August 15, 2010 - 08:17 AM
Along these lines.
I have a 99 WR400 and when I bought it the PO gave me the BD reg/rec. The instructions say it is for a WR450 and the stators are very different from one another. However, the plugs line up and would seem to work. But, would it? Also, could I use it without clipping the yellow wire and floating the ground?
TIA
  • William1
Posted August 15, 2010 - 09:56 AM
Kawi., I suggest starting your own thread. If answers to your question are posted here, it may confuse the OP. I will say, the BD rec/reg are designed for a floating ground system.
  • Kawidad
Posted August 15, 2010 - 10:08 AM
Fair enough. I just didn't want to clog things up with another thread that was on the same topic.
