07 tank shroud removal help
1 reply to this topic
  • Dee Perry
Posted August 11, 2010 - 02:43 PM
Had a hard get off this weekend. I am trying to get the shroud off of the gas tank. The nut that is somehow inset in the tank is spinning not allowing the bolt to come out. Any ideas? Tryed to pull the nut out of the tank but do not want to make things worse.
Edit: Was searching using wrong keywords--DUH-- Found the answer Thanks all.
  • gggsxr11
Posted October 21, 2010 - 02:31 AM
got the same problem i am getting new tank shroud so i was thinking of wrecking old shroud then drill out the bolt
