Tools
5 replies to this topic
  • vegasguy
Posted June 19, 2003 - 06:58 AM
Does anyone know where you can get the socket for the steering stem and the swing arm? I heard you can get it a Sears but not sure what they are called.
  • Rokatt88
Posted June 19, 2003 - 09:23 AM
I got mine at Pep Boys. I'm at work and can't check the socket size. What I did was use a cresent wrench the has measuring for size on the side and was able to get the size dialed . I believe it is 1 1/4" or 1 1/8". While I was there I got a 1 1/8, 1 3/16 & a 1 1/4" socket. I have been able to use all of them on my scoots! :)
  • vegasguy
Posted June 19, 2003 - 09:26 AM
Those are the slotted socket sizes? I will go to pep boys after work to check it out.
  • XR650Rrider
Posted June 19, 2003 - 09:52 AM
For the slotted one on the steering head, just use a set of channel locks. The torque value is so small you won't mess it up. For the swing arm pre-load you can make a set out of sockets using a dremel tool and cut-off disk. You can buy a disk brake tool at Autozone or Pepboys that I used the first time to remove it. There is a picture of it on the yahoo XR650 group in the files section. There is also a "Honda Oil Filter & Clutch Hub Spanner socket" that is sold by Motion Pro that is supposed to fit the slots. There is a picture of this at http://www.motionpro...icetools_3.html
You could also stick a couple of punches into the slots and wedge a screwdriver between them and take it out. Once you have it out try this link.
http://www.wtvl.net/n1rzc/preload/
  • secretatlas
Posted June 19, 2003 - 01:38 PM
nice post xr650rrider.
thanks.
  • vegasguy
Posted June 20, 2003 - 08:54 AM
Thanks for your help on this.
Washington
  • Hot  32 replies
  • Hot  35 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  186 replies
