09 YZ450F A little mild for my liking
29 replies to this topic
  • 03rkjc
Posted September 07, 2010 - 04:25 PM
#21
It is to my understanding that the cdi box is the same from 03 through 06 is this correct, and will those years work the same as the 06 box?
Posted September 07, 2010 - 05:15 PM
#22
No, it's not correct. Each year in that range is different, although they do share the same connector. Only the '06 box has the '06 map. The '05 was very mild mannered (lame), and the earlier ones were quite aggressive, but for a different set of cams, and lacked the top end pull that the '06 has.
  • husky390or
Posted September 07, 2010 - 06:05 PM
#23
Took mine out riding this past weekend with the Q4 installed. I don't believe I have to re-jet since it was running fine. The bike ran fine with plenty low end. Unfortunately I'm riding at 7,500' instead of 1,500' so right now it feels underpowered to me anyways. The other down side is I put one hell of a dent in the head pipe just in front of the guard when I tried to run over a pine tree. It won, I lost. Now it seems to have even more low end. :ride:
  • cjxrider125
Posted September 30, 2010 - 03:00 PM
#24
i found one on ebay thats off of a 06 yz250. it says it will fit on a 450. is that true? will this work on my 09 yz450 with the same results as one off of an 06 yz450?
Posted September 30, 2010 - 03:18 PM
#25
It might fit, but I wouldn't spend any money on it. The timing curve built into that CDI is for a two-stroke, and who knows how that would work on a four stroke? Pass on it.
  • cjxrider125
Posted September 30, 2010 - 03:29 PM
#26
im sorry, its from a yz250F, not a yz250 two stroke.:smirk:
Posted September 30, 2010 - 05:26 PM
#27
A 250F would also have a timing curve likely to be unsuitable for a 450.
  • husky390or
Posted September 30, 2010 - 06:33 PM
#28
FYI, I bought a Delkevic Titanium header for $100.00 and coupled with the Q4 I noticed a lot more bottom end on the bike. No problems pulling the front end up with a little throttle. It's running a little lean so once I jet it the bike should rip.
  • jennysmike388
Posted October 01, 2010 - 05:05 PM
#29
Throw an '06 CDI on it and you'll think there was a third option.
Im going to have to try this! I just got a very good deal on an 08 450. The guy already put a yosh pipe on it so im not to sure on how the stocker was but I heard it was horrid for mx . The guy also had Eleven 10 mods do carb work and I tell you what, it is just as snappy as the 09 crf450 I rode! How much do the 06 cdi's go for usually?
  • husky390or
Posted October 01, 2010 - 07:00 PM
#30
I paid $60 for mine off of ebay.
  • Hot  30 replies
  • Hot  50 replies
  • Hot  47 replies
  • Hot  36 replies
