Brake Cleaner vs. Engine Degreaser
17 replies to this topic
  • bikerdude11
Posted August 09, 2010 - 02:43 PM
Is there much of a difference? I have seen cleaners such as Brake & Parts Cleaner, which you can use on brakes and other parts. I have a can of Honda Engine Degreaser and was wondering if it is safe to use on brakes?
  • rusky
Posted August 09, 2010 - 02:45 PM
Engine degreaser is a different animal. Think of it as that hand cleaner (They call it Goop around here) but for your engine. It leaves a shiny/oily coat after you wash it off so I would not recommend it for cleaning brakes.
  • bikerdude11
Posted August 09, 2010 - 03:08 PM
Okay, thanks. I wasn't sure if it was a good idea, so I'll get some actual brake cleaner to use.
  • rusky
Posted August 09, 2010 - 03:32 PM
yea use either brake or carb cleaner. Brake cleaner is a bit cheaper most of the time.
  • Chickenhauler
Posted August 10, 2010 - 12:45 AM
Engine degreaser is usually based in kerosene or diesel fuel to 'soften up' the crusted on grease and crud so it can be washed away.
This is bad for brakes.
Stick to brake cleaner for brakes, carb cleaner for carbs, and degreasers for your hair after auditioning for Jersey Shore.
  • bikerdude11
Posted August 10, 2010 - 09:33 AM
Hahaha, thanks for the advice! Brake cleaner is safer to use in carbs though, correct? Carb cleaner will eat away at some of the parts?
  • MrBlahh
Posted August 10, 2010 - 10:26 AM
brake cleaner is some strong stuff, if your in california they denutted it, but the rest of us can still buy the good stuff with chlorine in it
  • bikerdude11
Posted August 10, 2010 - 10:34 AM
Denutted?
  • MrBlahh
Posted August 10, 2010 - 10:35 AM
Denutted?
california banned the good stuff and they have shitty weak brake cleaner, they cut the nuts off of it
  • bikerdude11
Posted August 10, 2010 - 10:42 AM
Oh okay, sorry I was reading it wrong. De-nutted. :banana:
  • Chickenhauler
Posted August 10, 2010 - 11:11 AM
Brake cleaner is really harsh on plastics and rubber items. It will melt plastics like an oven (if you have the good stuff). Remember, your float is made of plastic.
  • bikerdude11
Posted August 17, 2010 - 06:38 PM
Did you mean brake cleaner or carb cleaner? Would brake cleaner be safe to use on the carburetor jets when I pull them out?
  • yz144builderlol
Posted August 17, 2010 - 06:49 PM
ok so I got a question... is there anything that will leave the surface 100% clean and free of anything, even after the "spray" has evaporated?
I dont think its brake clean... I had a friend clean a glass ornament that had water with brake clean and it kinda left an oily/cloudy flim on the surface of the glass. kinda makes you wonder what it leaves elsewhere.
  • Chickenhauler
Posted August 19, 2010 - 01:45 AM
Brake cleaner is OK on jets, just keep it away from your gaskets, o-rings and float.
You 100% sure it was glass? It wasn't plastic of one type or another?
  • yz144builderlol
Posted August 19, 2010 - 08:01 AM
yes it was 100% glass
Edited by yz144builderlol, August 19, 2010 - 10:08 AM.
  • slow hand
Posted August 19, 2010 - 08:10 AM
Be real, real careful applying flame to anything that has been cleaned with chlorinated brake cleaner.
The flame can actually convert the residual chlorine into phosgene (a real nasty gas that has been used as a chemical weapon).
There have been cases reported of people suffering severe nerve damage and injury to mucous membranes after they cleaned a surface that they were going to weld with chlorinated brake cleaner.
  • yz144builderlol
Posted August 19, 2010 - 08:28 AM
damn... that sounds nasty. youd think they would warn you of that right on the front of the bottle?
  • GSP2
Posted August 19, 2010 - 08:57 AM
^ You're being funny right.
Use only in well ventilated areas
Keep away from heat and sources of ignition
Do not spray on a naked flame or incandescent material.
Do not pierce or burn aerosols, even after use.
Do not breathe aerosols or vapours.
Avoid contact with skin and eyes.
my first harescramble by ScrewMx_Hd
  • Hot  39 replies
why no more kick starter? by motf
  • Hot  53 replies
2007 450 SX-F Direct Injection by A Northern Soul
2006 Honda 250X Jetting Issues by MNThumper250
Dirt Bike   Make / Model Specific   Honda   CRF250X
  • 3 replies
  • Hot  28 replies
