2-Stroke with hot starting problem
6 replies to this topic
  • Robabob
Posted August 09, 2010 - 04:45 AM
Hi, I fairly recently bought an RM250 which when using it for my first Enduro I found it doesn't like to start when hot.
When I first got the bike it wasn't great at starting cold either but after a carb clean and fresh fuel that problem was solved. Since discovering the hot start problem the only thing I've done so far is change the spark plug which seems to have helped a little.
What things would you recommend checking first? Anyone else had the same problem with an RM?
Failing suggestions on how to fix the problem any exercise recommendations for the gym to build good kick starting muscles? :banana:
  • KcDavis
Posted August 09, 2010 - 01:52 PM
How is the top end? Maybe run a compression test. Usually 2t's are even easier to start hot than when they are cold.
Perhaps fuel flow is stopping somewhere in the line. Check the cap breather tube. Check the reeds, they can cause all different kinds of problems. Have you checked for spark when it's hot and not starting?
  • rusky
Posted August 09, 2010 - 02:44 PM
Check for air leaks, change plug, test coil, check reeds for cracks/chips.
  • pittss1c
Posted August 11, 2010 - 05:31 AM
My rm250 hot starts with the throttle wide open from the first kick. Doing that means that it starts on the first kick 98% of the time, but every bike seems to be different.
  • Robabob
Posted August 12, 2010 - 01:54 AM
Cheers for the suggestions. I'm going to work on the bike this weekend and check all these things.
What should the compression reading be for a bore in good condition?
  • pittss1c
Posted August 12, 2010 - 07:07 AM
Not sure. I imagine it depends a bit on your year. I have a 97, and a fresh topend has 185-190 PSI. I would think things would start going south near 130. (I have an old RM that is totally and completely worn out and it still shows 100 PSI)
  • Robabob
Posted August 12, 2010 - 02:06 PM
Cool, mine is a 98 so I guess it'll be similar to yours :banana:
Complete Noob found this bike on CL, good deal? by Camelot023
  • Hot  40 replies
05 YZ 250 Build by Moto_Ty
  • Hot  51 replies
Honda CRF250x Vs Honda CRF230f Vs Yamaha WR250f by Son_of_harry14
Dirt Bike   Make / Model Specific   Honda   CRF250X
  • 22 replies
KTM 300 XC-W 2016 by AAYERON
KTM 300 XC-W 2016
  • Last review by AAYERON
  • On August 22, 2016
Husqvarna TX 300 first rides by manandmachine
Dirt Bike   Make / Model Specific   Husqvarna   Husqvarna 2-Stroke
