Overheating
4 replies to this topic
  • 426OH
Posted February 03, 2001 - 05:42 AM
I'm a new member on Thumper Talk and this is my first four stroke. But I hope one of you can help me. I took my 2000 426 to my local yamaha shop to get the valves adjusted. When I got it back it couldn't run for more than a couple of minutes and the pipe would be glow red and the radiators would start to overheat. I took it back and they said the pilot screw needed adjusted.I am not sure they know what they are doing. I think they messed up the timing? I'm nerves about riding again ( afraid of seizing )Any Ideas on if I should ride or not? Thanks
  • Sandracer_uk
Posted February 03, 2001 - 06:16 AM
its normal for the pipe to glow red as the bike is on idle.
freak u out tho dont it !
if its boiling the radiator as u ride [ as opposed to sat with the engine running.
try adding a product called ''waterwetter''
and maybe a coolent bottle from a wr400
  • mike_dean
Posted February 04, 2001 - 02:05 PM
426OH, the cam timing off will make it run hot, does the power seem normal or is it lacking. It is normal for the radiator to spew if it is overfilled, and my pipe does glow red. I would have the cam timing rechecked. Good luck. mike
  • Hick
Posted February 05, 2001 - 08:34 AM
That is a familiar feeling for many after visiting their local shop. I stopped going.
You may consider checking the timing yourself, the manual is very informative and soon you will be smarter than your local mechanic, if you aren’t already.
Thumpertalk is even better than the manual. Search for the words “valve clearance” or try the “tech” section, here is a link to a good description of the procedure originally posted by Dougie: Valve Check/Adjustment, steps 1-7 is all you need to complete to verify your cam timing.
Hope this helps!
  • 426OH
Posted February 05, 2001 - 11:05 AM
Thanks to all of you that replied.
I didn't have any trouble with overheating until I got the bike back. I will try to check the timing myself to see if they set it correctly. Thanks again to all of you.
426 OH :)
  • Hot  38 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  30 replies
  • Hot  47 replies
