Jetting Changes for hi comp piston?
5 replies to this topic
  • Snapper
Posted August 04, 2010 - 07:48 PM
i have a hi comp piston installed - other than winding out the air/fuel screw 1/4 to 1/2 has anyone made any jetting changes?
('05wr450 - JE 13.5)
cheers.
  • proarm
Posted August 04, 2010 - 07:54 PM
Hi,
Every bike is different so a better idea is to use a wideband sensor to jet your carb.
I've got a cp piston 13:1 and I'm going to install it at the end of the month. I'll send you my changes then.
  • tribalbc
Posted August 05, 2010 - 06:14 AM
If anything it will like it a hair leaner. Trying turning the fuel screw in a bit, maybe go down one on the main.
I have a 13.5-1 JE on my 07.
  • GCannon
Posted August 05, 2010 - 07:59 AM
If your bike was jetted correctly before and the only modifcation is the piston and the displacement is the same. leave the jetting alone until you ride it and break it in. Then you can decide what if any changes need to be made.
  • William1
Posted August 05, 2010 - 10:19 AM
+2 on this
  • Snapper
Posted August 05, 2010 - 02:59 PM
thanks for that.
assuming it is run in i'm looking for peoples thoughts on what will need to be done.:banana:
