Leaking coolant
1 reply to this topic
  • rsumney
Posted August 03, 2010 - 06:29 PM
06 450 over heated due to loss of all coolant during race. Bike stalled out and was pushed back to pits. Replaced bad o ring on radiator now all coolant is coming out of drain hole on waterpump cover..What type of problems am I looking at. I havent taken cover off yet. Im hoping all it needs is a new gasket or seal. How big of a job could this turn into? Bike started after first kick today then I noticed coolant leaking out.
Posted August 03, 2010 - 06:40 PM
Water pump seals and probably an impeller shaft. Drain the coolant and oil, remove the RH crankcase cover, remove and inspect the shaft. You'll be looking for a groove worn into the shaft by the seal. If there is one, you need a shaft. Replace both seals and the bearing. You should also check the RH balancer shaft bearing:
http://www.thumperta...ad.php?t=785425
  • Hot  36 replies
  • Hot  47 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
