overheating damage
7 replies to this topic
  • rsumney
Posted August 02, 2010 - 07:33 PM
last race my 06 yz450f overheated due to losing all my coolant. I got the bike started for a bit and then shut it down and pushed it out of the woods. when i put new fluid in the radiator it all leaked out where the radiator hose goes into the head. I just got a new o-ring for that fitting and am concerned that i may have done damage to the head. Anything else i should worry about or just replace the o-ring put fluid in and ride?
  • mikedabike
Posted August 03, 2010 - 06:54 AM
I had a buddy do this. The entire motor was shot. You need to tear it down and look at it. When my buddy did it the piston got so hot it seized like a two stroke would. The piston was actually melted.
  • ttr250dude
Posted August 03, 2010 - 06:33 PM
i had the same thing happen on one of my snowmobiles. The rings were literally melted in the piston, you could see were the ring stopped and the piston started.
As for the rebuild, look at it this way: a top end rebuild is the perfect opportunity for a high comp piston :banana:
  • STROKEDIESEL
Posted August 03, 2010 - 07:44 PM
have you done a compression test yet?
Posted August 03, 2010 - 08:58 PM
This is why Yamaha doesn't publish compression test numbers:
http://www.thumperta...238#post9556238
  • xr650r2000
Posted August 03, 2010 - 09:01 PM
the cylinder would be scored
  • STROKEDIESEL
Posted August 04, 2010 - 08:48 AM
i am aware of this! i would think that a known good bike decompressed compression reading to compare to his would work ok. its also hard to decipher from just words without seeing first hand exactly how long/hard the bike was run after initial boil over. only the OP would know this. if in doubt though inspect and swap it out. it will be cheaper that way in the end if it does fail.. all that being said i can kick my bike over with out the auto decompression working(it hurts though) :banana:
a roll down the driveway would also work.
Posted August 04, 2010 - 09:36 AM
A leak down test is far more useful.
  • Hot  47 replies
  • 10 replies
  • Hot  30 replies
  • Hot  50 replies
