'03+ KTM wheel swap onto '02+ YZ
3 replies to this topic
  • carver
Posted August 02, 2010 - 10:48 AM
Has anyone done this swap and have the changes written down? Search didn't show anything.
Looks pretty extensive as the axles are different sizes requiring bearing swaps.
Edited by carver, August 02, 2010 - 11:04 AM.
Posted August 02, 2010 - 11:24 AM
I'm going to guess that you're on your own on this one.
  • carver
Posted August 02, 2010 - 11:29 AM
Yeah, figuring it would be a shot in the dark....heh.
Might be good to know though with all the recent YZ/KTM off road popularity.
I'll post up when the info. is avail.
  • carver
Posted August 02, 2010 - 12:48 PM
Well, as a follow up, front no worky even with a bearing swap, with factory wheels.
You can do the rear with a 25mm axle YZ conversion (new 450F size) and spacer swap.
But the front requires a 20x47x9 bearing which isn't out there. (14mm most narrow)
For a Talon or other hub, might work as they may use a common bearing O.D.,
but the stock front wheel O.D.'s are off by 10mm and to get the O.D. right,
it takes you out of the available width range for the bearing swap.
For future searches.
  • 0 reviews
Motocross
  • Hot  491 replies
  • 0 replies
