kyb and showa
7 replies to this topic
  • delmas
Posted August 02, 2010 - 04:15 AM
Are pressure springs changed the same way on KYB as Showa.
Posted August 02, 2010 - 07:29 AM
If you mean the inner chamber springs (ICS) over the inner cartridge free piston, not exactly, but it's similar, and quite simple. The entire base valve stem can be unscrewed from the free piston shaft with the valve itself intact. Then the piston just slides off.
  • delmas
Posted August 02, 2010 - 08:27 AM
Yes ,
I am clear on that part.But I do not see a lock nut on the stem like on the showa.
Posted August 02, 2010 - 09:08 AM
There's no jam nut. The upper and lower segments simply screw together. Use the compression valve removal tool clamped in a vise to hold the upper section while you unscrew the lower section from it.
  • delmas
Posted August 02, 2010 - 11:55 AM
thanks very much.Does KYB use any of that thread locker that I see in the Showa suspension and should some type of that product be used when putting it back together.One more question .With no jam nut ,does the upper and lower section have any adjustment to get the clickers in the correct position .
Posted August 02, 2010 - 12:39 PM
No adjustment, just run it together tight. I don't use a thread locker, but if I decided I wanted to, it would be BLUE Loc-Tite.
  • delmas
Posted August 02, 2010 - 01:32 PM
Thank you , great info and I appreciate it very much!!!!!!!!!!!!!!
I have a ton of experience with showa but this is my first time with kyb
thanks again
Edited by delmas, August 02, 2010 - 01:33 PM.
sp
  • delmas
Posted August 10, 2010 - 05:17 PM
the manual states there should be 20 clicks on fork compression.
mine has 18 .that is why I wondered about a jam nut and any adjustments.
  • Hot  38 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  113 replies
