when to replace a piston
8 replies to this topic
  • golybrown
Posted August 02, 2010 - 01:35 AM
i have a08 yz450 and was wondering what the sign of you needing to replace the piston are?
Any help would be appreciated as i am clueless about pistons
Posted August 02, 2010 - 07:24 AM
Tear down, inspection, and measurement are the only sure ways to know, unless there are some outward symptoms of trouble.
  • motochebyrashka
Posted August 02, 2010 - 08:24 PM
you can run the comprassion test just to get an idea at first.
  • ttr250dude
Posted August 02, 2010 - 10:18 PM
what should the compression be when cold?
Posted August 02, 2010 - 11:14 PM
Compression tests are fairly useless in an engine with automatic decompression. They're fantastically inaccurate in engines without it. Leak down tests are far more reliable. Have one done at a good shop.
  • nwbikerider
Posted August 03, 2010 - 07:40 AM
So, what would the outward symptoms of trouble be?
  • tech24
Posted August 03, 2010 - 07:44 AM
Burning oil and smoking, poor performance, and possibly some noise.
  • jmik517
Posted August 05, 2010 - 02:39 PM
alot of the old bike repair manuels I've read though list, poor starting as a possible sign of a bad piston or rings. Don't over think your way into a repair that didn't need to be made. I've seen alot of yamaha's with a bunch of hard hours on them, that haven't been touched.
  • Luigic81
Posted August 05, 2010 - 03:05 PM
You can buy a leak down tester for fairly inexpensive, but the percentage of leakage may not mean a whole lot to you unless you have a new engine to compare it against. Once you see a significant decrease in your leak percentage then you can determine if it's time to rebuild. A leak down tester will also help you diagnose if the compression loss is due to a piston/rings that aren't sealing as well as they used to, or if you have a leak somewhere else, like your valves or a bad head gasket.
I did one on my Husky SMR 510 that I used to have, and was leaking 12%, which I was told was ok to keep running for another season, but without a comparison percentage from when the motor was fresh, who knows.....
that said pistons are cheap, if you have 200 hours or so on your bike, just spend the $150 and do it
here's one on ebay http://cgi.ebay.com/...rts_Accessories
not sure why they show a 2 stroke piston in the pic :banana:
