KYB Fork Problem!
4 replies to this topic
  • iDuner
Posted July 31, 2010 - 10:16 PM
Ok well i was servicing my kyb dual chamber fork today. My problem is my Compression valve plastic piece is broken. Is there any where i can buy just the plastic piece and not the whole compression assembly. Thanks
  • Swapper265
Posted August 01, 2010 - 01:25 AM
Find your local KYB dealer and they can source you these parts individually, and more than likely will have them in stock. It seems as though you have already found out that Yamaha do not sell individually.
  • DBMX 925
Posted August 01, 2010 - 01:44 AM
Dave at Smart Performance can help you out. Even has a fix for that problem.
www.SMARTPerformanceInc.com - www.SPI-Racing.com
Contact info@smartperformanceinc.com - 408-406-2089
Engineering and Testing - KYB-SHOWA-WP
DIY tuning kits and OEM parts - Dell Taco - EPNP - CLOVER - 215.VM2.K5 - PHASE 4 (WR and KTM)
  • RJB
Posted August 01, 2010 - 07:15 AM
+1 on Dave. Took mine apart only to find the plastic cracked and in bits. Dave fixed me right up and his drilled replacements have been fine since. A whole lot cheaper than replacing as per the Yamaha parts catalog
  • crf450319
Posted August 01, 2010 - 09:40 AM
Here's a link started from someone who's had the exact same problem :
http://www.thumperta...ad.php?t=650136
And the "fix" for it :
http://www.smartperf.../YZMODASSEM.htm
This info is in the "Common Threads: Look here 1st! Mods, Maintenance, Common Issues and FAQ's" section at the top of the forum. Although it would have been better to have read it before your free piston broke, at least now when you replace the part you can perform the mod (I did) and you won't have to worry about this again.
  • Hot  28 replies
  • 5 replies
  • On January 15, 2017
  • Hot  36 replies
