Magura "Jack" Brake Tough Enough ?
2 replies to this topic
  • HighPlainsWR
Posted June 16, 2003 - 04:17 PM
I'm at odds with my bike tech. Usually he's right, but this time I think he's wrong.
Got a WR450 with a Revloc clutch and want a hydraulic left-hand brake with a T-Joint/Check Ball steel braided in to my rear caliper. I say a good juice clutch like a Magura "Jack" will do the job of actuating the rear brake calipers. He says it has to be a beefier juice clutch off a street bike (yuk !).
Who do you think is right ?
  • Brian_in_Long_Beach
Posted June 19, 2003 - 09:53 AM
Figure out the bore diameter and the stroke of the stock rear brake M/C and find something that is similar. Might be the Magura 'Jack' might not be. Somewhere around here there was a post with an aftermarket m/c set-up for this type of thing. Might try searching?
  • TeamScream
Posted June 22, 2003 - 06:26 PM
Another issue with the Magura Juice (clutch) is that it uses mineral oil and not brake fluid, so that rules that out as a brake actuator unless you rig a way for the rod that pulls in on the Magura slave cylinder to actually pull up on the actuator of the slave for the rear brake caliper.
