2007 yz450f carb prob
3 replies to this topic
  • mmott1474
Posted July 28, 2010 - 06:29 PM
Have a 07 yz450f thats bogs real bad cleaned the carb blow it out still the same bog?? Running complete stock jetting with a air screw anyone have a solution would be GREAT thanks
Posted July 29, 2010 - 08:09 PM
where in WA?
  • Wiz636
Posted July 30, 2010 - 11:07 AM
Yes, where in WA? And when did it start bogging?
The stock jetting works pretty well around western WA in the summer but if you are riding in eastern WA where it is signifiantly warmer and/or high up in the mountains then you are probably just running a little rich.
BTW your 'air screw' is actually a 'fuel screw'. Try turning it in a 1/4 turn at a time (makes it more lean) and see if that helps.
  • ssyz450fss
Posted July 30, 2010 - 05:09 PM
Ya I have same problem in CO and it back fires comming of the throttle. would like some jetting tips im adding a powerbomb and a Q4 also.
  • Hot  79 replies
  • 9 replies
Need help by Goforaride
  • Hot  68 replies
  • 5 replies
  • Hot  36 replies
