YZ250 guys, what tire pressure?
12 replies to this topic
  • Zach164
Posted July 28, 2010 - 02:28 PM
What tire pressure are you guys running for intermediate terrain motocross tracks on YZ250's?
  • sapp591
Posted July 28, 2010 - 02:51 PM
12.5 to 14 with a high quality gauge
  • dzamo
Posted July 28, 2010 - 04:39 PM
13 front and 11 in back when running dunlops/ 1lb less when running maxxis
  • kx500demond
Posted July 28, 2010 - 06:25 PM
Damn you guys run alot I always thought 7 was the ticket and 9 was high! LOL Guess ill have to rethink my pressures
  • brentn
Posted July 28, 2010 - 06:46 PM
13 front and rear for me.
  • sapp591
Posted July 28, 2010 - 07:25 PM
Depends on the tire gauge! I've seen 3 to 5lbs, between different tire gauges. Buy a good gauge, then test to that gauge to find the best pressure. On my gauge (blue point low press dial gauge) 12.5 to 14lbs works great.
  • Zaz
Posted July 28, 2010 - 07:26 PM
Brent is pretty close. 13 is about as low as you want to go to avoid pinch flats. The faster you are, the more you weigh, the rockier the track, the closer you need to be to 15psi. 12-13 for mud and sand. This is for current MX type tires such as the Dunlop mx 51. I am a 200 pound intermediate and I can almost guarantee a flat with less than 12psi in dry conditions.
  • brentn
Posted July 28, 2010 - 07:36 PM
Honestly anything lower than 13 I feel like the tire 'may' roll off the rim. Also when I hit larger rocks I cringe cause you can hear the rim making contact!!!
For me, at least the way I ride in the woods, 13 is perfect, anything lower and you're going to wreck something.
  • 06yz
Posted July 29, 2010 - 08:41 AM
[COLOR="Blue"]I ride 12 front and rear on intermediate terrain.
MAX!!![/COLOR]
  • 06kx250f89
Posted July 29, 2010 - 08:45 AM
i run 13 in my cr, i tryed 8 and bent my rim lol
  • BDubb106
Posted July 29, 2010 - 10:59 AM
I run 14 front, 12.5-14 rear depending on how the track condition is wet/ dry.
  • adam728
Posted July 29, 2010 - 12:37 PM
As others said, depends on the tires and gauge. Terrain and tubes play a roll as well.
With something like a Maxxis Desert IT rear I might run as low as 8-9 psi with slimed up ultra hd tubes. Only one pinch flat, and nothing was going to survive hitting that buried water tank, cut both tires wide open.
Typically I'll run 10-12 psi rear, and 13.5-15 psi front.
  • RCannon
Posted July 29, 2010 - 03:16 PM
EVERY Dunlop Tire truck I see at the races lists 14. Tires feel squirmy to me under 13 lbs.
And as you know..all the top racers use the exact same dunlop tire we buy......yea, sure they do......No, I think there are so many tuning options available that I stay stuck on suspension and such before I spend much time on tires.
Oh, I use nitrogen. It does not leak out between rides and stays cool. Top riders like myself hate heated tires increasing pressure..LOL
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
Yamaha YZ85 2017 by Chris.GVS
Yamaha YZ85 2017
  • 0 reviews
Yamaha YZ85 2016 by Chris.GVS
Yamaha YZ85 2016
  • 0 reviews
Yamaha YZ250 2017 by Chris.GVS
Yamaha YZ250 2017
  • Last review by oneTRICKYZ250
  • On December 30, 2016
