Supermotoing a 2008 WR450F
10 replies to this topic
  • Mr-Brightside
Posted July 27, 2010 - 01:14 AM
Just a coupole of quick question I have. I understand wheels from 2003-2008 will fit my bike. Will the speedo work still? I know the wheel size will be smaller but the hub part number is the same on the yamaha parts website.
Also will the sidestand be too long??
Can I use a braking 4pot caliper with the standard master cyclinder?
any help thankfully received....
Mr B
  • YamaLink
Posted July 27, 2010 - 10:55 AM
I believe Trail Tech and/or Pro Moto Billet make SM sidestands.
  • cat0020
Posted July 29, 2010 - 01:16 PM
If you use OEM front hub laced to 17" rim, then you can keep your speedo/tripmeter working. Aftermarket hub will not have the notched washer at the hub bearing to activate the mechanics of the speedo/tripmeter.
I keep the OEM sidestand on my 04 WR, I am careful wherever I park, make sure there is enough lean to keep bike secure.
If ou can find a caliper that fits the brake mounting points, or a proper adaptor, you can use any pot caliper, just make sure there is enought space between rotor, caliper and forkleg.
  • klossWR450
Posted August 01, 2010 - 12:30 PM
I have '07WR in SM trim, wheels will fit, my SM hubs are excells with no speedo fittings so I had to fit Vapor but it is so good I wouldn't swap back, had to grind off the end tip of the sidestand to make it safe with 17" wheels, I have 4 pot Braking caliper too, kinda works with stock master cylinder but is very soft, you should get 16mm diameter master to make it work as designed
  • tweav
Posted August 01, 2010 - 07:50 PM
yes you can fit wheels from older wr's and yz i think its 99 to 08 . if i remember right , but you may need to make spacers to make them fit right . the stock speedo will only work on a wr hub . no big deal because it sucks anyhow , vapors are much better . they have temp, speedo ,tach ,time , elapsed time , trip meter and a real odometer . "instead of the stupid yamaha one that resets after 999.9 miles at least thats the way it is here in the states . As far as the 4 pot brake goes they suck with the stock lever . you would be better off with the whole stock setup adapted with a 320 mm rotor . or a whole real brake setup either one . the stock lever is just not enough to make it work right.
yes the kickstand is a bit too long too, but it does work. i cut an inch out of the middle of mine and welded it back together . i don't anybody makes a direct replacement shorter kick stand for a wr .but I think you can make a yz one work
  • SXP
Posted August 02, 2010 - 06:23 AM
Welcome back! It's been awhile...where've you been?
  • tweav
Posted August 02, 2010 - 04:20 PM
i was ignoring my wr . I had a very long series of stupid issues with it's yearly overhaul . starting with me killing bambi with it ,and going for the 60 mph tumble down the road. I didn't really get hurt much neither did the wr . surprisingly the only real damage was a broken front fender and a bit of roadrash on the plastics . but then I decided to go over it from stem to stern and had the wrong parts time and time and time again . it put it together wrong once . blew the starter up . I ended up so mad about it as the riding season slipped away. I when and got me a new cbr 1000 ,to fill the void until the wr decided to get it's act back together. anyhow it's back on the road now . it not quite tuned in right but it's back out there.
  • racinteach
Posted August 08, 2010 - 05:03 AM
A quick question, in sumo mode on my wr my front tire eats away at my fork guards. Anyone else have this issue?
  • tweav
Posted August 08, 2010 - 02:17 PM
yes the stock wr fork gaurds rub . i reshaped mine with a heat gun at first , but now I run trimmed yz ones. because I don't have the wr speedo sending unit on mine anymore
  • racinteach
Posted August 08, 2010 - 09:36 PM
Thanks, that is what I thought. yeah no speedo here..using a trailtech.
  • tweav
Posted August 09, 2010 - 07:48 PM
you do need to hold them out a little when installing the screws on the the yz ones . but they do fit much better . lite trim only ( maybe the white ones i have needed no trim the black ones needed a little off the in side) no heat gun required either way
