426 clutch issue
3 replies to this topic
  • nugie
Posted July 26, 2010 - 06:12 PM
I have a 2000 yz 426 that I just picked up a motor for from ebay and started bolting it in when I noticed the clutch had zero tension other than from the little spring. What could this be and would the motor have to be split to do any work on the clutch?
  • 09speeddemon
Posted July 26, 2010 - 08:12 PM
Just pull the side cover off on the left side. there is 7 or 8 bolts in a circle and see if there is even clutch plates in it. Very easy job (you can change and install the clutch by removing this cover only)
Posted July 26, 2010 - 09:33 PM
It's normal to an extent. Connect the cable and try adjusting before you panic.
  • nugie
Posted July 27, 2010 - 02:15 AM
no no I have the old motor right next to me and lots of tension on that one. Im guessing there is probably no clutch in it
  • Hot  47 replies
  • Hot  28 replies
  • Hot  38 replies
  • 10 replies
