WR426F crash. Springs or Tires
1 reply to this topic
  • BCN_Runner
Posted June 16, 2003 - 07:30 AM
Did anybody had a crash braking hard a WR426F on the street?
A few months ago I had it. Fortunately I always wear helmet and protections, and I can explain it.
I was driving too fast in the city (over 50 miles/h) crossing a bridge, but just arriving to the top, I see all the traffic stopped, I braked hard with both brakes, the front wheel start to slide, I attempt to control the lever several times but the bike starts to sway quickly and I was launched to the slope of the bridge sliding in parallel with the bike (only one glove wasted up to burn my hand, but not too serious).
When I repaired the bike (handlebar, brake lever, right white cover) I thought the problem could be the front springs too hard, I'm very light (only 130 lbs) so I changed it to two size softer. The bike improved on all conditions, and now when I'm braking it has more front sinks, like if I were more heavy, but I can't still block the front wheel lifting the rear on the street.
I think it must be necessary. Is possible that stock tires (soft rubber) could be the problem?
With other off-road tires can I brake safety on the street?
Thanks or any helpful advice
:thumbsup:From now I will follow your advice:
NEVER DRIVES FASTER THAN YOUR GUARDIAN ANGEL CAN FLY
Thanks
  • wrkaholic
Posted June 16, 2003 - 11:04 AM
I lost it in a similar situation in the dirt. Personally, I think it is the Dunlop 739 front tire. It just washed out from under me. I do not like this tire. I ride mostly on looser stuff.
