what is this l shaped part?
2 replies to this topic
  • Snapper
Posted July 25, 2010 - 12:48 AM
ok *** is the L shaped bit i found under my bash plate?
i decdided to clean my bike a little bit (no it's true)
behind one of the bash plates i found this bit.
when the bike blew it's head gasket i actually stopped riding it because it started making a hollow noise as if the header pipe had fallen off -
appears that it was this which is just above the header pipe and appears to be in a hole which is straight thru to the exhaust port.
I can only guess that the block got hot (due to blown head gasket) and it then fell out?
hopefully it will just push back in to place?
  • Snapper
Posted July 25, 2010 - 01:01 AM
I think it is the bung from the decomp hole?
why did it fall out?
Edited by Snapper, July 25, 2010 - 02:18 AM.
  • Snapper
Posted July 25, 2010 - 03:48 AM
it's in the manwell afterall - not under the cylinder head section or the exhaust section but tucked in with the carby - it is where the "Air Induction System" would go - obviously something not on the ADR delivered models.
now how to make sure it doesn't fall out again? (loctite and snot)
