bent magneto/rotor removing
2 replies to this topic
  • tobias6371
Posted July 23, 2010 - 06:59 AM
in the process of removing a horribly tight magneto i think ive bent/cupped it as it now contacts the inside of the cover.out with file??
  • William1
Posted July 23, 2010 - 08:02 AM
If you did in fact warp it, you must replace it. You want a several pound hunk of metal wobbling?
  • William1
Posted July 24, 2010 - 03:59 AM
Using a three arm puller, no wonder it is bent. You must replace it. You should of used the correct puller, it is easier and the puller is cheap (abut $20 USD).
