90/100-21 front tire?
5 replies to this topic
  • colinf713
Posted July 23, 2010 - 04:18 AM
What do you guys think about running the 90 instead of the 80? What are the differences and do you like it or not?
  • Jim813
Posted July 23, 2010 - 07:52 AM
I've had good luck in the Desert with the Dunlop 745 in the 90/100-21 size. If your riding a bigger bike, the wider tire up front helps the front end track smoother and straighter over rocks. I have not experienced any bad traits with the wider size.
Posted July 23, 2010 - 08:07 AM
I tried a 90 once, and it was OK on firmer ground, but in sand it had a tendency to skate on top instead of cutting in and biting.
  • BBrown626
Posted July 23, 2010 - 06:42 PM
I ran them for a while. They seemed a bit better and I felt they provided more protection from big hits, but they aren't available in all brands. I went back to the std size.
  • dunn2500
Posted July 23, 2010 - 08:35 PM
didnt like it, as someone mentioned it wanders too much and made the steering feel heavy.......i noticed it on any terrain, also felt i lost some accuracy and seemed like it was harder to pick and stay in lines............felt kinda mushy and never seemed to "plant"
  • Wiz636
Posted July 24, 2010 - 09:02 AM
I use the bigger size if I am going to be racing somewhere that is rocky with higher speeds just for a little more sidewall and rim/flat protection. Otherwise I stick with the 80.
  • On January 15, 2017
  • Hot  36 replies
  • Hot  50 replies
  • 5 replies
