rear wheel
5 replies to this topic
  • nugie
Posted July 21, 2010 - 06:01 PM
Ive got a question. Ive recently bought a 2000 yz 426 and was told you had to replace the whole rear wheel when the bearings got bad instead of just replacing the bearings, and that it was a solid unit that the bearings were a part of the wheel. Any truth to this?
  • mikedabike
Posted July 21, 2010 - 08:01 PM
You should be able to replace the bearings unless the hub is damaged.
Posted July 21, 2010 - 08:43 PM
Did the same guy offer to sell you a bridge? Or a rear wheel, maybe?
It's BS. The wheel bearings are entirely serviceable.
  • 09speeddemon
Posted July 21, 2010 - 09:17 PM
LOL! that's like saying you cant change tires
  • nugie
Posted July 22, 2010 - 02:32 AM
Ya I figured it was BS. Thanks guys!
  • Digger01
Posted July 22, 2010 - 06:43 AM
I just did this when I redid my rear wheel (rim bent bad). I replaced my rim, spokes, sprocket bolts and bearings. But I had to dremel the last part of one of the bearing out of my hub after bending the bearing puller.. everything else was easy.
I would get a nice long punch and buy the bearing puller and after soaking it with a pbblaster type spray, then I would cut the race if it doesnt budge.
Good luck.
Wish I had poder coated the hub but I was trying to stay on a budjet.
  • Hot  38 replies
  • 0 replies
  • Hot  36 replies
  • 10 replies
