2010 YZ450F oil leak
5 replies to this topic
  • eckstine918
Posted July 21, 2010 - 04:09 PM
I have a 2010 yz450f. The oil filter cover is slowly leaking oil. Everything is clean and see no problems with the cover or mount area. I replaced the oring and it did not do anything either. It is slow enough that the only reason i see it is due to the dust colecting on the oil. Anyone have this problem? What did you do?
  • norcal_hoss
Posted July 21, 2010 - 05:07 PM
I did and it was because the oil filter was falling sideways everytime I put the oil filter cover on. It doesnt stick in there just falls over so I started laying the bike on its sideputting the filter in then putting the oil filter cover on sideways with the top screw hole at like 10 oclock then turning it clockwise until it lined up. So far it has not leaked since. Maybe it will help.
HOss
  • eckstine918
Posted July 21, 2010 - 05:26 PM
thanks, i will try that.
  • delmas
Posted July 21, 2010 - 05:54 PM
HOss
i have done the filter change like that from the start and so far no problems
  • whiskey wheelie
Posted July 21, 2010 - 09:51 PM
I was having a similar issue... it was coming out by the side gasket cover though up on the top where the upper oil filter cover bolt goes into the case through the gasket... checked my torque on the bolts and they were a little tight. Changed the oil, re-torqued to spec and no problems since.
  • 95s10nj
Posted July 22, 2010 - 08:03 AM
Make sure the oring isn't pinched. I pinched the oring one time and had a slow leak but I haven't had any problems since replacing the oring.
  • 5 replies
  • 10 replies
  • On January 15, 2017
  • Hot  47 replies
