Scotts or GPR
30 replies to this topic
  • desert rider7
Posted July 21, 2010 - 03:35 PM
Im just wonering which one is better. I ride desert if ones better for that
  • Chas_M
Posted July 21, 2010 - 03:55 PM
Take your pick. In the 1000's of posts on 'which damper is better', about 75% favor the Scotts and 25% favor the GPR or some other brand.
The reasons most favor the Scotts is in the variety of adjustments available and especially for the fact that the Scotts has separate and independent adjustments for low and high speed damping.
  • fender bender 59
Posted July 21, 2010 - 04:02 PM
Where did you come up with that 75/25 crap????? Was there a poll that I didn't see???
Both are good stableizer... GPR's are a little cheaper and have FREE servicing And much easer to use..
  • BKRacing
Posted July 21, 2010 - 04:10 PM
I heard Scott is a copy of GPR, I thought there was even a lawsuit over patent infringement. Im sure they both are great though. I have a GPR, I got a great deal on it, it has surely saved my ass many times, and I think it's great.
  • Eric@ScottsPerformance
Posted July 21, 2010 - 04:58 PM
Desert Rider-
Our damper has three circuits of adjustment, Low Speed, High Speed and Sweep or range of damping.
1) Low speed is your overall resistance to turning. Going flat out out in what ever gear and having the bars shake due to the front end being light. At slower speeds or situations where you need to turn the bars you run less damping- at higher speeds like Baja type stuff you would normally run more damping
2) High speed damping has nothing to do with speed of the bike, but it is all speed of the bars. It is easier to think of it has a backup valve for the low speed- It works when your bars take a sudden hit and they try to "jerk" out of your hands and you have the Low speed set loose. You use less of this damping when the Low speed is set tighter. Very good for motocross and tight terrain.
3) Sweep is where the damper starts and stops damping. Our damper starts in the center of its stroke and dampens outwards and then can break free at 4 different points so you do not have to "fight" the damper to turn your bars. It also offers free return back to center for the same reason. Again, motocross and tight woods terrainwould want the damper to break free sooner than a full on Baja speed.
If you go to our website you can download the actual manual that will explain in greater detail how this all works. I will attach a file that will show the install applicable to your bike.
Also remember that our damper is fairly universal. If you buy one for your Honda this year and then turn around and buy a different bike next year you you can get new mounts to put the damper onto the new bike. We do make a mount to put the damper above your handlbars or SUB mounted below the bars which will raise them about an inch.
Finally, all of our dampers are hard anodized or heat treated to prevent wear and oil contamination. We use a "quad" design seal on or main shafts the prevent leaks (very similiar to todays x-ring chain seals) and we stand behind ANY manufacturers defects. All parts are made in America, although SOME of the older dampers were made in Sweden by Ohlins to our specs. We have been selling the damper since the mid-late '80s and we have been in business ourselves since the early '70s.
http://www.scottsonl...litrack/154.pdf
Thanks-
Eric
  • desert rider7
Posted July 21, 2010 - 05:07 PM
Thanks Eric. My dad has a scotts on his Husaberg and it works great. This is more for future reference when I get my KTM 450.
  • lazydog
Posted July 21, 2010 - 05:09 PM
gpr is pure crap. I've had one. Not even comparable to scotts. free service... funny... more like no service. and no high speed.
  • crftrevor
Posted July 21, 2010 - 05:23 PM
what a dumbass claim from one person who doesnt like gpr LOL!!!!!lazydog your out too lunch on service ive had 3 of them and theve serviced them for free even after the year was up, not just that but i had a race in the spring and needed it back from them within the week when i had damage from riding(my own fault) and they fixed for free and rushed shipping back at no cost. you might have had a bad experience but just say that then, instead of speaking for everyone when it sounds like you know nothing about it.Ask around ato the next few races your at and see what the general response of GPR service is, then you might get it(if youve ever been to a race) by the way i also use a scotts on one of my bikes but just because of the seperate high speed dampning but for a recreational rider you cant go wrong with GPR.
  • lazydog
Posted July 21, 2010 - 05:26 PM
Hey watch it, your gonna hurt my feelings. GPR is crap.
  • crftrevor
Posted July 21, 2010 - 05:44 PM
im pretty sure no one is going to listen to your dumbass comments bro LOL!!!!
hey desertrider if youd like i can hook you up with some good guys at GPR theve always been helpful but as i said it sounds like if your riding all desert you should be going with the scotts for the high speed, the boys at GPR would likely tell you the same!
  • desert rider7
Posted July 21, 2010 - 07:01 PM
OK thanks for all the feedback guys
  • Chas_M
Posted July 21, 2010 - 11:01 PM
The unbiased estimate comes from the 1000's of testimonials in numerous threads on Scotts vs other dampers in ThumperTalk.
  • MasterT2000
Posted July 22, 2010 - 03:10 AM
Wrong! The Scotts damper was around way before GPR and they are nothing alike.
  • BKRacing
Posted July 22, 2010 - 06:20 AM
I wasn't knocking either one, but that is what I heard a while back, on TT .
  • Wrfrk
Posted July 22, 2010 - 06:27 AM
I've used both and currently run a GPR v4 but only because I got a really good price on it. If I could choose again I would go right back to Scotts. Sure the GPR is a good damper but the Scotts is so much more adjustable and just seems to work better. Do yourself a favor and just buy the Scotts, unless you can get a killer price on a GPR. Most shops sell them for the same price, IMO for the same price it's a no brainer......SCOTTS!!!
  • crftrevor
Posted July 22, 2010 - 07:24 AM
yes i totally agree the scotts is much more adjustable and versitile, i got my GPR V4's at a good price as well but i really was impressed with the service and i dont do much high speed riding but i dont think, as i said before anyone will argue the scotts is far more versatile.
  • Wrfrk
Posted July 22, 2010 - 07:27 AM
The high speed dampening is NOT for high speed riding!! It's more like a second degree of dampening in which it operates when forces are applied at a higher rate or speed of force.
  • TommyB 754
Posted July 22, 2010 - 07:43 AM
Scotts is a much better unit. More mount options and better performance. I've had 2 GPR's also and couldn't stand them, the dampening back to center drove me crazy.
  • yz144builderlol
Posted July 22, 2010 - 08:47 AM
ding ding, this is why scotts is better.
so... heres the final tally:
votes for scotts: 237 :smirk:
votes for GPR: 13
get a scotts, theyre amazing!
  • crftrevor
Posted July 22, 2010 - 11:22 AM
yes wrfrk i DO understand this but the larger impacts of force acting on the front wheel unexpectedly are usually at high speed ie. your hitting rocks roots etc. much faster with harder impact.
Squish or #8 slide? by yz dude
  • Hot  27 replies
What did you do to your 2017 FE501 today, ECU, TPS and mods etc. by crazybrother
Dirt Bike   Make / Model Specific   Husqvarna   Husqvarna 4-Stroke
  • 7 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
Differences between the F and FX? by motoxpress
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  49 replies
2015 wr450 engine knock. Video inside. by cdf450
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  58 replies
