99 wr400 reg/rec battery wiring
2 replies to this topic
  • redneckj
Posted July 21, 2010 - 08:19 AM
Baja designs has a reg/rec part number 12-203. They say that you dont have to do the floating ground mod to use this part. https://www.bajadesi..., (dc) (unwired)
Has anyone used this part on their 99wr400 with good luck. I would like to convert the bike to a DC system and add a battery to make everything work well on my plated bike. The main reason for doin this is to add a HID headlight and making the horn blow (if need be). I am sure that you need to remove the factory reg/rec and replace it with the BAJA designs piece. What wires do you use from the factory wiring to attach to the 2 yellow wires on the Baja designs reg/rec? Thanks in advance!!
  • PBDBLUE
Posted July 21, 2010 - 11:13 AM
Not exactly true. You don't have to float the ground as long as you keep the case isolated from the frame and you do not connect any of the DC "-" leads to the frame ground. It's not difficult to do. Just mount the regulator inside the airbox and connect all the "-" leads back to the battery and regulator. PM me an email address and I'll send you a schematic.
  • holy_demon
Posted July 25, 2010 - 08:02 PM
hold on a sec. i have a '00 WR400 so does it runs on just AC? cos i tried to get the mech to do e wiring and stuffs and all he did is to put a newly charged battery(works fine only for a week or so). and after that, the batt don't work.
and what does a regulator/rectifier does for a wr400? does it basically turn it from an AC to DC? so all i need is to fix this reg/rec into my bike and my bike is fixed?
btw, where do u store the batt? i keep mine in the air box and i'm not sure if that's a right place for it to be. and any good recommendation for a battery that suits well with a wr400.
i'm totally lost on this. sigh... sorry for hijacking your thread bro!
