Sisneros Speed Works products!
93 replies to this topic
  • Eddie Sisneros
Posted 20 July 2010 - 05:12 PM
SisnerosSpeedWorks.com for quick and easy purchasing of Sisneros Speed Works products and fuel injection tuning services.
Sisneros Speed Works Super Start kit
Sisneros Speed Works  "Free Power Mod" harness
Sisneros Speed Works high clearance choke assembly for the fcr-mx
Sisneros Speed Works pricing for RHC cams/valves,SSW springs
Sisneros Speed Works cap on coil conversion
Sisneros Speed Works single pull quick turn throttle
Sisneros Speed Works Manual Fan Override Switch
Sisneros Speed Works Crankshaft Inspection Plug
Sisneros Speed Works 50hp package
Sisneros Speed Works Cam Chain Service Kit
Sisneros Speed Works Oil Change kit
Sisneros Speed Works Engine Install / Top end Service Kit
  • Sal Sisneros
Posted 21 July 2010 - 08:34 AM
i was wondering when u were going to put all ur products in one thread
  • smrookie
    troller
Posted 21 July 2010 - 11:41 AM
Bitchen' !!
The list is growing slowly, but surely.:smirk::smirk:
  • Eddie Sisneros
Posted 21 July 2010 - 12:40 PM
there are more to come!
  • ptgarcia
Posted 21 July 2010 - 01:49 PM
Sounds like its about time to build a web page.
And where's the link to some t-shirts? :smirk:
  • Eddie Sisneros
Posted 21 July 2010 - 01:56 PM
all coming,dont worry. everyone will pleasantly suprised when the plan comes togeher.
  • Sundog
Posted 21 July 2010 - 06:47 PM
:smirk::cry:
//DOH...gotta burn the checkbook...
  • bumtarder
Posted 26 July 2010 - 09:17 AM
hey eddie,any plans on offering your turkey baster coolant recovery tank mod as a kit?
  • Eddie Sisneros
Posted 26 July 2010 - 11:08 AM
interesting thought.
if there is demand i will produce it.
  • Sal Sisneros
Posted 26 July 2010 - 10:13 PM
i demand u produce it
  • Eddie Sisneros
Posted 29 July 2010 - 06:41 AM
i appreciate all the orders!
ive got throttle kits,start kits,cap/coil kits and chokes in stock and ready to ship!
  • ROMAD
Posted 02 August 2010 - 02:50 PM
+1 on the Turkey baster kit.
A couple other ideas for those of us that hate chasing parts all over town or dealing with minimum order prices from Sudco:
- CE removal kit: a couple vaccuum caps and the proper PAJ or adj screw and maybe a pic or two.
- OEM jet/3x3 kit: Most everybody comes to you for jetting anyways, why not offer the OEM jets and needle/clip as a kit. I know it took me a couple trips to local places to find OEM jets and even then I was sold the wrong jets and had to go back to get the right style jets. Lost a whole Saturday running around chasing the right $5 jet. Throw in a 3" putty knife and a pic or two just to make it complete. Maybe even offer (as an option) a 'high altitude' jet with the parts if the buyer had freqent trips to a significant elevation.
- AP mod kit: For the dremel challenged or those that just dont want to grind on their own parts. Throw in some safety wire and a pic or two. I know the diaphram isnt cheap but maybe a core fee and swap out could work? Would be really cool if there was some sort of bushing that could be fitted to the plastic arm so help repair it or keep it from getting so egged out.
- TPS block off plate: I hate having that pig tail sitting there unplugged knowning it isnt doing anything. Maybe a milled out cover piece that would allow the TPS to be removed, the hole filled and the throttle shaft properly captured :banana: If it wasnt stupid expensive I'd like one just to clean up the carb area. I think Dr.Honda made one for a personal project once, looked cool.
I am sure there is some more cool stuff lurking in the SSW research lab that would sell if it saw the light of day. Sorry if this isnt the proper place for the ideas, just want to see SSW thrive!
Edited by ROMAD, 02 August 2010 - 03:08 PM.
  • Eddie Sisneros
Posted 02 August 2010 - 04:10 PM
all good ideas.
  • bumtarder
Posted 04 August 2010 - 10:47 PM
eddie,didn't see it on the product list but i assume that the "free power" mod harness is still available thru you apart from the super start batt kit.if so,i'll need one for my E model.is it still $10 shamolians?
  • Eddie Sisneros
Posted 05 August 2010 - 05:39 AM
yes,i still offer the harness.
$10 shipped.
  • Eddie Sisneros
Posted 06 August 2010 - 09:07 AM
"free power mod" harness added to the list. not new but now has its own listing.
  • KLRBach
Posted 07 August 2010 - 09:34 AM
Hi Eddie
My (your) 440 BB motor in my '00 plated E ran great at the Adv WMRS run last weekend.
So now the next step is address the suspension and the ergonomics.
Are you doing any suspension work/products?
I have to pull the front and rear suspension apart and put all new bushings,bearings,chains,sprockets etc in to replace my  broken/worn out parts.
For ergonomics, I have to do something to get the bars up since I'm 6'7" and 280lbs. I recently added the offset DR Rizers and that helps alot but I need to do something about taller bars. Can you recommend a taller bar? Will your throttle kit work with rizers and a taller bar?
So my wishlist for parts from Eddie.
Cap Coil
New throttle/cable that will work with taller bars/risers
Turkey baster coolent recovery system.
plus...
a fastener replacement kit...  for all the common sizes of fasteners
bearing replacement kits
chains sprockets
oil/air filters... and associated crush washers
and a list of services you offer...  such as engine rebuilding
suspension services if any etc.   now that you are in your new location.
HTH
Randy from Burbank
  • Eddie Sisneros
Posted 07 August 2010 - 10:40 AM
im still doing and offering all the same services.
suspension,motors,complete bike builds,repair,etc etc.
my throttle will work with taller bars.
im not sure which is most popular bar bend currently.
i prefer the cr hi.
i will make another pinned thread with common services prices.
  • Goebz
Posted 11 August 2010 - 07:04 PM
How about a fully mode, jetted FCR with everything needed?
This is going on my Christmas list.
(I Am at 1200 ft)
PM me if you need to.
  • Eddie Sisneros
Posted 11 August 2010 - 07:28 PM
no problem.
just let me know when you are ready.
