Suspension oil
5 replies to this topic
  • delmas
Posted July 18, 2010 - 02:28 PM
I know Gray will have the answer on this one.
What weight oil should i use for forks and shock.
I am used to 5 weight on showa in the forks,
2.5 on the shock
KYB need advice!!!!!!!!!
Posted July 18, 2010 - 02:53 PM
My first choice is to use 215.VM2.K5 fluid from SMART Performance. Use SPI #3 in the shock and in the inner fork cartridge, and the heavier SPI #5 in the outer chamber of the fork.
Second choice in Amsoil Shock Therapy #5 Light in the shock and fork cartridge, and #10 medium in the outer chamber.
Running the heavier oil in the outers allows you to run a slightly lower oil level but still resist bottoming.
  • delmas
Posted July 18, 2010 - 02:57 PM
thanks
  • PAdaytonaman
Posted July 19, 2010 - 08:04 AM
Penske Racing's MX and ATV division, called Axis Racing shocks, runs proprietary fluid in the shock and Bel Ray fork Oil 3W up front. They tested everything on their shock dyno's and nothing else worked as good in the forks. Not even their own fluid, which wasn't suited for the forks.
I think they know a thing or two about suspension. They build all of their own shocks for Indy, Nascar and MX/ATV. I'm not sure if they sell their fluid to the public, but its in my stuff after they revalved and serviced my suspension.
Posted July 19, 2010 - 10:37 AM
So does Dave Johnson. :smirk:
  • CaptainKnobby
Posted July 20, 2010 - 06:15 AM
I second that.:smirk: That Del Taco kit is sweet and really makes a difference on a 2010 YZ450.
