CRF250R 2009 jetting problems
5 replies to this topic
  • excalibur174
Posted July 17, 2010 - 12:46 PM
Hello
My buddies got a Crf250R 2009 with a pro circuit pipe on it and he's having jetting problems. He says its bogging on certain big jumps. Does anyone have some jetting set ups that have worked with the pro circuit pipe?
thanks
  • Keith72
Posted July 17, 2010 - 01:30 PM
procircuit has jetting specs on there website that might be helpful.
  • excalibur174
Posted July 17, 2010 - 10:59 PM
thanks ill pass him the info
  • WALKINGWOUNDED
Posted July 18, 2010 - 07:56 AM
Did the 09 still have the 'fuel sloshing away from the main jet on hard landings' problem. I'm only mentioning this so he doesn't get to fat on the main to compensate for another problem, a rob himself of needed hp.
  • csclocogato
Posted July 19, 2010 - 06:38 AM
this was my first thought as well, dont remember who makes the new bowls off the top of my head?
  • Ron Hamp
Posted July 19, 2010 - 11:23 AM
R&d makes the bowls and this helps i had some local fast a riders with the same problem they were increasing main jet size to huge numbers to compensate like a 188-190 and yes that will hurt the power a bit .the velocity in the port is to low for good engine rpm recovery as soon as they put an RHC ported head on the problem went away because of the increased velocity also the carb on the 06-09 bikes is just to big in the venturi they actuall will make more power with a specialy bored 37 mm carb with a 39 mm venturi and they will regain rpms much quiker.
2004 CRF250R HEADLIGHT by fsmith1221
Dirt Bike   Make / Model Specific   Honda   CRF250R
  • 4 replies
  • Hot  36 replies
Tried shiming my valves today. Help! by Steven942
  • Hot  26 replies
Steam/white smoke coming out of crf250r by Seth McKenzie
Did I get a good deal?-2011 CRF250R by BTYZSquad
  • Hot  47 replies
