06 450 transmission question
3 replies to this topic
  • wr450motard
Posted July 10, 2010 - 11:31 AM
my 06 wr 450 motard slips in 5th gear, it feels like the clutch is shot but feels fine in the other 4 gears did anybody ever run into this before?
Posted November 21, 2010 - 12:08 PM
hi, i had a shop replace all internal bearings and after the first ride it started slipping in 5th gear and only in high revolutions, did you find the problem to yours?
  • rick wellsy
Posted November 23, 2010 - 05:20 PM
Your 5th gear dogs are probably worn. You will have to replace the two gears adjacent to the shift fork. Good luck
  • Mr-Brightside
Posted November 25, 2010 - 04:12 PM
Try removing the clutch plates and oil them in engine oil. If that don't work looks like you will need to replace the gears as stated..
